Looks like its time to replace my anodes
Results 1 to 14 of 20
    Default Looks like its time to replace my anodes
    For what ever reason... I found it interesting what a season and a half in my motor did to these. I would show the other one but it is gone completely. I'd like to think my heads look better than this.
    okie, lake Texoma
    Looks like a good idea to keep some in there.
    H8-2-W8
    5.89[email protected] first pass
    Just out of curiosity what is that?
    okie, lake Texoma
    its a plug with a sacrificial metal attached(usually Zinc) that will keep brackish water from eating at aluminum parts of your engine. It just eats this instead.
    H8-2-W8
    Dallas, TX
    Is there any benefit to running these in fresh water? I noticed my intake was pitting around the water ports the last time I had it off. This was after half a season. Where do you install them? Intake, Block, Head, Does it matter?
    Isn't there an anode is all hot water heaters? Seems like it is a different material depending on water hardness in the area. That is not brackish water.
    Wet
    Wet is offline
    East Hampton, CT
    Do you always run in salt or brackish? If one is missing, and one half gone, I would replace them more often. Zincs will usually protect until there is nothing left, then they will wear on the metal it's supposed to protect. Even with that little stalgtite you have, I'm sure it was doing it's job.
    okie, lake Texoma
    Just about all water has some salt content and minerals that will take there toll especially on aluminum so yes the anodes are a good idea. If you have ever noticed, all outboards have them as well as lower units to protect them. They are usually ate up if their very old.
    you can screw them into just about any hole that goes into the cooling system.
    heres a link were you can get'em
    http://www.boatzincs.com/engine.html
    H8-2-W8
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    i thought galvanic reaction was caused by the rotation of parts and dissimilar metals in a wet enviroment
    Dallas, TX
    Thanks for the link. Those are much cheaper than Summit. I'll be adding them to both boats this winter.
    The Right Coast/SE-PA
    Question
    Where would you install them > in the block drain locations?
    In an open cooling system once the engine is off, water normal drains out to the water pump inlet holes.
    For what its worth...I got a anode lesson a couple of years ago when I blew up my 427....it was 2 seasons old. My heads were getting eaten alive. Btw...no brackish water here......just fresh.
    Quote Originally Posted by thompy View Post
    Don't quote me on this....but i think the term electrolysis ...or some thing like that comes into play here...
    sacramento
    thanks hass for the link . with all my alum., i have been wondering where to get these. can you also bolt on a piece of copper somewhere also or not?
    The Man cordog009's Avatar
    East Texas
    Thanks for that link Hass. I'd gave up trying to find those things a while back.
    1984 Youngblood TX-19 SOLD
