hp for AAA imp
Results 1 to 14 of 71
hp for AAA imp
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    Default hp for AAA imp
    what kind of hp needed to drive a berk AAA to 5000 rpm
    Quote Originally Posted by thompy View Post
    If you did a search for a chart...I bet you would find one. Unless you have or want to make room for a 9.5" impy....you don't need to worry about a "aaa" cut....unless maybe a hi helix from duane.
    In what? A Battleship or a canoe?
    okie, lake Texoma
    Whats the difference? The pump doesnt know the size of the boat. It should make the same rpms if its tied to the dock.
    H8-2-W8
    [email protected] first pass
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    19 ft CobraJet, I see an AA takes about 495 hp at 5000 rpm havent seen a chart with the AAA.
    going to build a 500 caddy, just to be a little different
    The Man cordog009's Avatar
    East Texas
    AAA is going to take some serious power to turn, I know there's a chart here that shows them on it, just can't find it at the moment. That caddy motor is gonna cost an arm and a leg to build vs the usual BBC BBF or even SBC.
    1984 Youngblood TX-19 SOLD
    sacramento
    Default estimate only
    about 550-600?
    So load has nothing to do with RPM and Speed achieved?
    Bullhead City, AZ
    On my application it takes aproximately 450hp to turn a 9.5" impeller to 4400rpm.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    okie, lake Texoma
    The pump shouldnt know the difference.
    H8-2-W8
    Menominee, mi UP
    Aug 2009
    Menominee, mi
    the boats shape and weight will affect your speed but dosent affect what the pump will do.
    using the caddy because to about 500 hp 630 ft pds torque not much more than other motors to build and about 70 lbs lighter than a BBC
    Maybe the pump! but it will turn the RPM given. Now please don't tell me a free riding hull vs a barge is going to see the same RPM with the same H/P.
    The Right Coast/SE-PA
    Why wouldn't it???
    If you took given engine and pump out of a super light 16' boat and mounted it in a 55' Sea Ray...you don't believe engine would turn the same RPM?
    It sure as heck won't do the mph but why wouldn't it spin the same rpm?
    Does the engine/pump know what it's mounted to?
    If both pumps are loaded at 30 psi they just might.
    S CP
