BB CHEVY intake question
Results 1 to 5 of 5
    Salem,Or
    Default BB CHEVY intake question
    okay im running a torker 2 intake on my 496 stroker at this time while breaking in the motor, but thinking about going to a merlin, dart, Vic 2...but why do I see only 6 holes on each side of the manifolds to bolt down. on all the pics I have looked at.....shouldnt there be 8 ???
    With Spray there is a way!!!
    Senior Member Alter Ego's Avatar
    Jun 2010
    South Arkansas
    You will notice that on alot of performance intakes, even some of the other edelbrock models, will only have six bolts perside rather than eight that the stock intakes have. I have never had a problem sealing with them sealing. In fact, and I am sure that someone with a lil more knowledege will chime in if I am wrong, but alot of the aftermarket heads do not have this hole drilled and tapped so that it will not cause problems later when/if someone decides to do some crazy port work on them.
    Quote Originally Posted by BrotherWolf View Post
    I know my brodix heads were missing a hole or 2 as compared to stock. It sure threw a kink or 2 when it came time to bolt my ski pylon up.
    May 2010
    Discovery Bay, CA
    I am running Victor 2 on my 468 and it does not have the holes between the intake ports like the stock manifolds do and I have had no problems with mine I did use gaskets that are designed for this hole pattern though since the ports in the gaskets match the ports in the heads
    Break Out AnotherThousand
    Salem,Or
    thanks guys....
    just checking I seem to buy the wrong stuff every now and then
