Bennett Hydraulic Diverter Pumps ?
Results 1 to 12 of 12
    Bullhead City, AZ
    Default Bennett Hydraulic Diverter Pumps ?
    Does anyone have any info: 1) wiring and 2) solenoid timing. Also testing specs. Mine is putting fluid out both side on the up or down. I am running -3 line instead of -4 but that shouldn't cause this.
    Jim & Amanda Rich
    CJ 72 & 53c
    JR Performance Motorsports
    Concord, CA
    Default Bennet
    Contact them in Florida. There helpful
    Jerry
    Anaheim/BHC- the Shack
    Solenoids are paired left rear/ right front, and right rear/ left front. If you're using a true Bennet motor (unmodified by Place), only one wire is used. The other is cut off and unused.
    Cas
    Cas is offline
    Angry American Cas's Avatar
    yellow wire is actually cut off in the boot and does not connect to the blue wire....I think that's what was determined.
    B1 Racing cs19's Avatar
    probably one of 2 things. Diodes took a dump or you got a piece of trash in one of the solenoids. Take them apart carefully and look for the smallest piece of trash.
    Quote Originally Posted by Squirtin Thunder View Post
    Jim as said above is this a Place unit or original Bennett might have missed this?
    Bullhead City, AZ
    My bad, its a Place Diverter unit.
    Chris you were right, one of the diodes took a dump.
    Now it seems to be slow, is it the hose/fitting size that is causing this?
    Jim & Amanda Rich
    CJ 72 & 53c
    Bullhead City, AZ
    Do you guys think or know if by going to a bigger line, -5 or -6, would increase the speed of the diverter?
    Jim & Amanda Rich
    CJ 72 & 53c
    Sep 2008
    OC, CA
    Jim,
    I added the Banderlog relay that draws direct off the battery. Diverter moves quick now with stock hyd lines. Not sure on the effect of -5 or -6 lines, would like to know the effect.
    Cas
    Cas is offline
    Quote Originally Posted by cp562 View Post
    Jim,
    I added the Banderlog relay that draws direct off the battery. Diverter moves quick now with stock lines. Not sure on the effect of -5 or -6 lines, would like to know the effect.
    ditto
    http://www.banderlog.com/products/po...owerRelay.html
    Can be done with Bosch relays too, but the Banderlog unit is, simple, ready to go, and bullet proof. Significantly speeds up the trim speeds
    2012 Predator 2372
    Jul 2014
    St Louis
    Mine has two different types of plungers in the Solenoids. 2 that have a spring that is physically attached to the end in addition to the normal spring that goes into the bottom. And 2 with only the small spring that goes in the back of the plunger that and then into the solenoids. My problem is I have NO clue which goes where. I have spent HOURS trying to figure if its a bad solenoid or a misplaced spring. I had a bad seal and got water into the lines and when cleaning it out mixed everything all up.
