455 Rebuild - Jet Mad
Results 1 to 14 of 31
    "Mad" Member Jet Mad's Avatar
    Cape Town, South Africa
    Default 455 Rebuild - Jet Mad
    Some pictures of my current 455 Oldsmobile rebuild.
    Wikus
ID:	89971   Click image for larger version.
ID:	89972   Click image for larger version.
ID:	89973   Click image for larger version.
ID:	89974   Click image for larger version.
    South west Colorado
    Jet-
    Looks great! hope mine, when I'm done, looks just as great and runs even better!
    Cheers!
    Dec 2009
    Okanagan Valley B.C.
    NICE... I likey the outside
    Give us the details on the innards
    Quote Originally Posted by bcfloater View Post
    1. .40 Icon Forged Pistons (Lightened) 14,5cc
    2. Nascar Rods.
    3. Clevite 77 bearings .10 Mains and Big Ends.
    4. "N" spec Crank.
    5. Bearing clearance on Mains and Big Ends .0035"
    6. HV Oil pump- Relief shimmed for higher pressure.
    7. Main Cap studs with straps.
    8. Oil restricters on mains 1-4
    9. Oil restricted cam bearings & Push Rods
    10. Block decked
    11. Iskey 292 Marine Cam.
    12. Timinators oiling mods on block, oil pump and crank.
    13. -12AN drainbacks to oil pan.
    14. Edelbrock Performer heads - CNC ported.
    15. Timing Gear Set.
    16. Fully balanced .- rotating assembly.
    17. Totalseal 2nd gapless file to fit rings.
    Wikus
    Dallas, TX
    Looks expensive.
    Very nice piece.
    Default Some more pics
    I would have fired her up today, but I broke a 45* XRP fitting on the water feed system, already ordered from CP Performance.
ID:	89996   Click image for larger version.
ID:	89997   Click image for larger version.
ID:	89998   Click image for larger version.
ID:	89999   Click image for larger version.
    Yucaipa, California
    who's alternator bracket is that? Mondello's? I need one.
    1992 Eliminator Daytona 21'
    Quote Originally Posted by Tahiti Boss21 View Post
    Tahiti Boss,
    I got it from Junior at Mondello's, It is nice and compact, good quality and is very easy to install. The fan belt is also quite short, no vibrations and it is nicely tucked away.
    Wikus
    Southwest corner AR
    Looks real good! I hope it performes as well as it looks!
    The guage for water pressure is a bit to high of pressure no. about 30 to 40 max I would think would be better! JMO! I may be looking at it wrong!
    That should be the talk of South Africa for sure! WT
    WT
    WFL Crew!!!
    Dallas, TX
    Metric. 12 PSI = ~ 83 kPa
    The gauge is Kpa, and I run it at 90Kpa - about 15 PSI if i remember correctly.
    Wikus
    Southwest corner AR
    Quote Originally Posted by Jet Mad View Post
    Wikus
    I knew I was wrong! WT
    WT
    WFL Crew!!!
    It has been exactly 12 months ago that the motor spun a rod bearing. I have done research on the Olds engines for a solid year. I implemented a lot of stuff and advice that I got from the PBF forums and some more.
    I have experimented with different set ups and combinations, did a lot of testing on my test engine and came to a couple of conclusions on Olds engines.
    1. Get the oiling system sorted. - drain backs from the heads, mods to the crank, restricters, correct oil pump and pick up and most important, fit an oil cooler .
    2. Use marine grade gaskets.
    3. Correct bearing clearances.
    4. Forged pistons with Nascar I beam rods.(slotted on both sides.)
    5. Balance the rotating assembly.
    6. ARP fasteners. - Rods, mains and heads
    7. Correct valve geometry.
    8. Measure and check your machinists work five times and check everything again.
    . One last thing,"If you are not a praying man, an Olds will certainly make you start praying. "
    Just my opinion.
    Wikus
    Yucaipa, California
    looks good man!
    What oil pan did you get? Windage tray?
    I have a dooley w/no windage tray yet and wondering what to run.
