which one can go faster 18' or 19' cp
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 54
    Jun 2010
    Default which one can go faster 18' or 19' cp
    Trying to find out info on the hull limatations , mph ect for both
    B1 Racing cs19's Avatar
    What exactly are you trying to do? 18s are quick 19s can be quick too but might top end a little better, the 18 will win more races, they are deadly quick when you get them setup right which isnt hard to do.
    Senior Member hotbo's Avatar
    lake Ouachita AR
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Jun 2010
    Going to be a drag boat. I heard that they will flip at a certain speed do u knw what that is
    " Live Laterally " Dominator's Avatar
    Phoenix
    Quote Originally Posted by cpracing View Post
    18' then. Any boat can flip at anytime. Why not a tunnel?
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    Speeds beyond 118 can be an issue, but truth be told you can flip a boat at 80 if it's not set up correctly.
    There are a few 19's that have run past 120 but they are the exception to the rule.
    What's your power going to be and how fast or quick are you looking to go ?
    S CP
    Jun 2010
    I have a 19' that's weighs 375 I need to knw what the max limitations are for the hull (mph) ect.
    Jun 2010
    It will be around 1250hp
    A CP with a bit over 1,300 ran a 8.006 at 116.
    http://www.performanceboats.com//sho...ght=red+dragon
    You can do a search of Red Dragon.
    Quick CP had an blown Alky engine making more tham 1,500 but I don't remember the weight of his boat ( CP 19).
    S CP
    Jun 2010
    I will thank you
    IMO a 19 is a bit more challenging, its doable just have respect for it and always keep in your head IT CANT SHUT OFF on you, good wiring, no cheap parts and you should be ok. Do some research on setup and engine placement, thats alot of power for a light 19, you could tip that over if you tried hard enough.
    Jun 2010
    Everythings going to be brand new. Once the motors done ill be bring the boat down to get the pump work down by u and jack. Are the rachets easy to install? Or when u guys do the pump work would it be more benifical to have u guys install that as well. Boats been Flipped speed coat and pump was set back about 2 inchs
    Ratchets go on fairly easy, Id just have it done at the time of assembly, couple small things need to be taken care of to set it up properly for a ratchet when you assemble it.
    Chris
