E85 compatible question
Results 1 to 7 of 7
    Okmulgee Okla.
    Default E85 compatible question
    I am currently changing my fuel delivery setup to a pair of E85 carbs and was wandering what fuel filter I should run that would conect to 10an fittings and be E85 compatible
    Also conserned about the filler hose that conects to the tank. I dont want to have a lot of black crap in my fuel system from a filler hose breaking down any thoughts?
    well the block is GM any ways
    IS UNDER FIRE
    okie, lake Texoma
    H8-2-W8
    [email protected] first pass
    Sep 2008
    OC, CA
    www.ramcoperformance.com
    The 300M is the best.
    so they have e85 in okmulgee now? well maybe it'll trickle on down to here eventually
    Okmulgee Okla.
    Lord have mercy, what happened to the $5 fuel filter. LOL
    Looks like an Areomotive A 2000 or a B/G 400 fuwl pump. A FlowMax filter. And about 1 1/2 ft of alcohol compatable filler hose + 2 steel braded lines from the tank + tank mods.
    Looks like I will have to burn 2100 gal. of E85 to pay for the change. Guess I will start early next summer
    Any thoughts on which pump is better.
    IS UNDER FIRE
    Okmulgee Okla.
    Don't have it in Okmulgee. Have to drive 20 miles to get it in Gleenpool. at 2.50 per gal.
    But I was driving that to get AV gass @ 3.80 per gal.
    IS UNDER FIRE
