Cam break-in on the trailer
Results 1 to 14 of 21
    Senior Member jet460's Avatar
    Mar 2010
    Modesto, Ca.
    Default Cam break-in on the trailer
    Just put new heads and cam in my 460.
    I need to break it in on the trailer.
    Any way I can do this with the
    pump hooked up?(Expecting a "hell no!")
    The drive line is a major PITA to install or remove with the motor already in, or at least it looks that way.
    The motor is out, and going in this weekend.
    1st time doing it this way.
    Help me out here, please....
    100 years from now, none of this will matter.
    Certified Wildman! Sanger Flatbottom's Avatar
    May 2010
    Antioch, Calif (NorCal)
    I don't know what kind of pump you have, but my Berkeley has a hose coupling on the inlet with a cap you remove to hook up a hose (need to make a short hose with 2 female ends for an adapter). It feeds the motor and I have ran mine several times with no problems. I have done this quite a few times for initial fire ups, however I wouldn't let it run for hours... The other option is to leave the d-shaft coupler disconnected if you are worried about the pump.
    Everything electrical has smoke in it.... and it's not done till you let the smoke out!
    Mar 2010
    Modesto, Ca.
    Quote Originally Posted by Sanger Flatbottom View Post
    It's a berk 12jc.
    The hose fitting pumps out of the pump, not in, so the pump would be dry if I leave it hooked up to the motor(drive line).
    I need to run it for 20-30 minutes to break in the new cam.
    My understanding is that is a no-no.
    I can hook a garden hose up to the motor no prob, but I don't want to cook the pump.
    Senior Member PonyFiveO's Avatar
    Feb 2009
    Southbay to the Central Valley
    Couldn't you just back it down the launch ramp at Modesto Res, and break it in while strapped to the trailer? Set your reverse bucket halfway open like you are in neutral. You should have the ramp all to yourself and be able to run it as long as you need.
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    Quote Originally Posted by jet460 View Post
    It's a berk 12jc.
    The most easy way is to unhook the driveline. Its not too bad doing it on mine.
    Sep 2008
    Yuma, Az
    would you rub your johnson on sandpaper for 20-30 minutes?
    no, so remove the driveline.
    boatless....
    Quote Originally Posted by YumaJet View Post
    Menifee
    'bout sums it up right there......
    Keith...
    Mar 2010
    Modesto, Ca.
    I know, I know. Stupid question.
    But fantasy is free, so why not ask anyway.
    I did try to shave my head with a cheese grater once, but I don't drink any more, so...
    Redding, CA
    If you look closely down at the floor here, you can see the hose bibb with a gate valve on either side of it. The front one goes to the Engine/ headers, the rear one to the pump.
    I hook up the hose, get flow through the engine, then pinch it down, open the rear one and flood the pump. I also pinch down the engine dump at the Thermostat housing to maintain full water level in the engine.
    It works for firing before towing to the Lake, but I would be VERY hesitant to run it for any length of time like a cam break in.
    Tommy
    The age long strife I see
    Many names, but always me."
    Gen. George S Patton
    T&Y
    T&Y is offline
    Sep 2009
    I run a hose connection that splits the water between the pump and engine anytime it's running on a trailer..... BUT I wouldn't run it like that for a "Cam Break In" session. Too high RPM's and for too long in my opinion (I don't claim to be a jet expert). Last time I did this I took it to Elsinore, talked to the guy and the gate, and he told me as long as I didn't actually back it off the trailer he wouldn't charge me anything. Worked out good.
    If you could disconnect the driveshaft that would be your best bet.
    would you rub your johnson on sandpaper for 20-30 minutes? no, so remove the driveline.
    interesting analogy Albert
    Southwest corner AR
    Before installing the motor break it in on a motor cradle! Then install the motor in the boat! Check around someone has one that you can use! Just a thought!
    WT
    WFL Crew!!!
    Coby Broke this BBF in On the Shipping "pallet" we made before it went to Louisiana , bout ready to build a similar device from steel to do just what your talking about Tom
