mark4 short oil filter
Results 1 to 14 of 18
    Senior Member junkyard's Avatar
    PHX AZ
    Default mark4 short oil filter
    Does anybody know what the part# is for the short oil filter on a bbc mark 4 block?
    Shell Knob, MO
    Wix 51069
    PHX AZ
    Thx, also found out the fram# is ph30 or ph25
    The Right Coast/SE-PA
    Talking
    Quote Originally Posted by junkyard View Post
    FRAM = ewwwww!
    k&N HP-2002
    Shell Knob, MO
    With Fram, you buy now AND pay later.
    PHX AZ
    Lol.The fram# was just to cross the# .
    Chantilly Va.
    Dont cross the PH 25 no, that is for a Buick and Olds. Cross the PH 30 no.
    delco p# pf454 is the short high volume gm filter, you can cross it to a k&n or wix from there
    Wow! I can believe you used the words hi volume when talking about that POS. High volume compared to what, using a fuel filter? No matter what brand you use, that short POS couldn't keep up with a BBC with even the tightest clearances. What ever you do, don't remove your bypass.
    notice i said cross it to a wix or k&n gm produced the newest pf454 and pf1218 to fix a oil gallery volume filling issue they had back in the early 90's on trucks with oe oilcoolers and higher volume oil pumps that accompanied them, and for the average joe jetter that dont spin above 6k the filters are fine. i was jus giving the guy a p# to cross, but again you have to be a dickhead bout it.
    Yeah I know. But even a K&N or a Wix is dubious at best. I would avoid that Smart car filter. I think I would try and squeeze a Mobil 1 302 in there. The K&N and the WIX are great filters, but if I absolutely had to run the pint size POS, I would run a Mobil M1 202. And again, don't even think about removing the bypass. Damn I hate that filter. There is nothing in my boat I couldn't remove or fix or delete, that would make me run that POS
    One Free Call Does it All CP Performance's Avatar
    Rohnert Park, CA
    We carry Moroso Racing filters, they are 5.25" tall. Never had a problem with them.
    http://www.cpperformance.com/s-1-new-products.aspx
    Brad
    CP Performance
    One Free Call Gives You Access To Over 500,000 + Items!
    800-225-9871
    x2, if it came to that i think i'd look for a decent remote filter set-up somewhere lol
    Quote Originally Posted by CP Performance View Post
    Brad
    I think he is in need of something shorter than that. I am guessing he doesn't have that kind of room. The PF454(PF25) is only about 3.3 maybe 3.5 long. If he has 5.25" of room, he could run the PF35L or the PF1218
    Did Delco stop selling the "L" series filters. Or only don't make them in a PF45 number. I liked those filters.
