Swing Away Tonge
Results 1 to 14 of 16
Swing Away Tonge
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Default Swing Away Tonge
    Has anybody ever purchased a swing away tonge kit? I didnt even know they sold this until i started searching for swing away tonges (thought it was a custom weld on deal) but apparently there are kits you can find that can be bolted on.
    Here's a quick one i found that overtons sells.
    http://www.overtons.com/modperl/prod...=FROOGLE_76683
    My boat will fit straight at my new house in the garage but only if i can get the tongue out of the way!
    San Clemente, Ca
    Here's another, this one is more expensive but it looks like it includes the tongue along with the extension bar, longer chains, etc..
    http://www.trailerpartsdepot.com/ite...530101&eq=&Tp=
    Salem,Or
    I have one on my trailer and there sweet to have
    With Spray there is a way!!!
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Make it yourself! 2" sch80 square stock, 1 1/2" sch80 square stock.
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Senior Member kidd bill's Avatar
    Silverton,OR
    I looked into the swing away tongues before doing mine but the problem i had was they attached to a single tube where as i needed mine shortened further back into the v part. I ended up doing a reciever style, I can slide it in for storing than pull it out a throw the pin in it if i ever finish the boat to take it to the water.
    Our family ski boat (Malibu Response) has one similar to the overton's one you linked. Works great.
    Senior Member Futs's Avatar
    Orange CA, Big River
    I did mine myself. 1/2" steel plate, welded chromemoly round stock for the hinge and drilled four holes to run bolts through. Works great and only take a minute to take the bolt out to swing it out of the way.
    Quote Originally Posted by kidd bill View Post
    This whole set up is pure hot rod....The fenderless screams kool...Makes your boat look fast and sick just sittin there.
    Clovis, Cali
    No info about the prefab ones, but heres another home made one. Ironman on here made it for me a few weeks back, 3" square tubing and 1/2" plates, works great.
    San Clemente, Ca
    I though about having this trailer modified but i'm still not 100% sure i'm going to even keep this trailer. When i originally got this trailer i though it was for a 18' boat, but now with my boat on it i've realized that it's probably really for a 19'. My tongue weight is very light, i can lift it myself... I slide the boat forward about 6" which helped but it really needs to go forward another inch or two. So I'm thinking i may be on the hunt for another trailer, one that was hopefully setup for a southwind or anthony bottom. I just dont want to sink too much money into this trailer if it's going to go... This bolt on deal isnt too expensive and i like how it comes with the new bar, tongue and chain holder.
    Anybody know what it would likely cost to have a custom swing away fabed up (welded) to a existing trailer?
    Sep 2008
    Yuma, Az
    propless, looks like a heavy duty fab!
    shaun, i would much rather go with a welded on plates like props, then the bolted on tongue.
    boatless....
    Jul 2010
ID:	99405Click image for larger version.
    San Clemente, Ca
    CY, are you going with the weld-on or bolt on. I actually need the 3"x4" version which is rated for like 7000 LBS. Should be more than enough for such a small boat i would think.
