daytona question for the experts
Results 1 to 7 of 7
    Senior Member hydroman916's Avatar
    Sep 2008
    sacramento
    Default daytona question for the experts
    I am thinkin of changing out the dominator for a berkley, the pump I'm lookin at has a long droop, question is, will a long droop work on a daytona
    get blown or get blown away
    Dec 2010
    why change them out, the dominator is a good pump and has a stronger suction housing. the long droop will work on the daytona, it however may not give you the best performance depending on your horsepower range. i have found that, to me, depending on the set up and the bottom work that the best speeds we obtained with the daytona type hulls was with a short droop or standard nozzle housing properly wedged for the set up. just my.02
    corona calif
    Default Daytona
    When you say long droop are you talking about a standard droop or is it the extra long droop that was availiable back in the 70's. What year is the Dominator pump you are planning on using?
    B1 Racing cs19's Avatar
    Alot depends on the intake that your running, if its a low profile I would stay away from a full droop.
    Why not just run the droop youve been running and bolt it up to the new pump?
    Is the boat your talking about the one in your sig line?
    Sep 2008
    sacramento
    yes that is the boat in my sig line, the only reason I am thinkin bout changin is cuz the new pump is a full show polished one and has a stainless A impeler, there is nothin wrong with what I have just wantin the bling
    Wet
    Wet is offline
    East Hampton, CT
    Bling doesn't add ANY mph. It actually slows you down...
    when you factor in the time you spend polishing it.
    Sacramento area
    Cory does the dominator pump have the old style bowl?
