Electric to manual jetovator?
Results 1 to 14 of 24
    South west Colorado
    Default Electric to manual jetovator?
    Have an electric Jetovator set up, is it as easy as just substituting a manual lever for the electric control and maybe a longer cable?
    Thanks in advance.
    Shell Knob, MO
    Quote Originally Posted by Fabreezai View Post
    Thanks in advance.
    Pretty much. You may have to drill out the top hole where the cylinder mounted to accept the cable.
    Sorry, I was thinking Place Diverter
    California
    If its an actual Jet-o-vator it can be done like you decribed it. I've been told they are a little stiff on the upstroke while under way.
    South west Colorado
    Thanks Josh,
    it is a actual jet-o-vator. I have also heard that with the electric set up, while under way it will strip the gears in the drive on the upstroke, thats why I want to convert it. I have the pump out and apart right now and want to keep an eye out for a lever in the spam section. Have lots more to do to the hull (replacing the stringers) before it's ready to be reinstalled. Thanks everyone for the input!
    Senior Member wolfie's Avatar
    Thanks Josh,
    I've thought about doing the same or switching to a Place. The Jet-O-vator is much too slow to raise and lower.
    South west Colorado
    Quote Originally Posted by wolfie View Post
    What did you end up doing or have you?
    Norco
    I wanna go from Elct to Hyd. Not happy with the Elct on.
    Wet
    Wet is offline
    East Hampton, CT
    I stripped out one of the gears in mine. That long gear is a bitch to find, and I spent a fortune having one made.
    The only way to keep it from happening again was to let off the throttle, raise the roost, then mash it again. Getting it to go down again didn't seem to be a problem.
    Norco
    Mine just wont go up all the way. Cable moves freely. Nozzle moves free. New motor. Still wont go up. If I help it just a bit, it goes. Like the motor does not have enough torque.
    Quote Originally Posted by danhercules View Post
    Dan We have expirimented with a simple Screw type servo to control the cable on these vs the original windo motor/box design and it worked well I'll dig out some pics if your interested Tom
    Haven't done anything yet...
    Might wait until Tom post pics of his new servo!!!
    Dec 2010
    have seen the original jet-o-vator use an off the shelp ac delco power windowr motor. the part number is on the gear assemble and can be had thru napa and i assume other auto parts. think i have paid under 30.oo locally for the assembly. was told that the parts were obsolete but found out that this is still an off the shelf item.
    Norco
    Oh yes, please. want my email or ya gonna post em?
    South west Colorado
    Yes! please post pics, would love to see em!
