Identifying Berk 'R' intake
Results 1 to 9 of 9
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    Default Identifying Berk 'R' intake
    What should one look for? Does anyone know the casting # off hand?
    Senior Member Sleek Freak's Avatar
    Hooper Utah
    My super jet intake has a R cast into the top.
    Quote Originally Posted by 75 TX View Post
    Do your'e self a favor and google "berkeley jet boat pumps" and get the correct info from the source. Ol Guy.
    Whats that suposed to mean? if it's on the internet it's true..... A long gone item, getting harder to come by.
    You will notice they don't acept standard under water hardware.
    Senior Member Futs's Avatar
    Orange CA, Big River
    H-2780 is the casting number on mine. Sleek is correct, it wont take standard hardware. It has 2 long runners underneath and it takes 6 bolts to bolt up the loader.
    The superjet is the same thing, just accepts standard hardware.
ID:	99647   Click image for larger version.
ID:	99648   Click image for larger version.
    B1 Racing cs19's Avatar
    The pockets under the shoe and the odd loader mounting is a dead giveaway, they look very different than a standard intake, Youll know one when you see it.
    Culver City, Ca
    Thanks for the responses gentlemen.
    Nope, not an 'R', just a stocker I guess. It's machined for a shoe and rideplate and has had some blending done to it. And whoever installed the shoe must have run outta anti-seize because the old slotted bolts are stuck.
    Try some heat not a ton cause it can soften up the epoxy but enough to free it up. Big adjustable wrench on the screwdriver helps too.
    Culver City, Ca
    I finally got the intake out. They used slotted hardware on the shoe and rideplate. Lame. Two of the 4 rideplate bolts put up a serious fight, but I finally got 'em. 3 of the 4 shoe bolts still won't come out. Should be easier with the intake out....maybe.
