Top mount starter & bellhousing
Results 1 to 14 of 16
    Senior Member speedealer's Avatar
    Albuquerque,N.M.
    Default Top mount starter & bellhousing
    Who makes the top mount bellhousing and what starter do u use. need it for BBC
    Kingman/Golden Vly, Az
    Quote Originally Posted by speedealer View Post
    not sure who makes the bellhousing...mine has no name on it...i got it from Kjell (on the boards)...the starter is a CMI clone...i got it off of EBay from DB Electrical in Johnson City, Tenn...just remember, it has to be a CCW starter!
    FastRat
    Glenwood marine also makes top mount bellhousings and they use 2 bolt top mount starters. i have (3) of them if your interested in one.. also have a couple of immi high torque starters that fit . pm if interested.
    jan at lightning mfg. makes the rail kits and top mt bellhousing, also check with tom at jet boatperformance.
    Angier, NC
    Quote Originally Posted by johnray069 View Post
    x2 got mine from him for my stwd well worth the money and time saving when u have starter trouble keeps it away from the water better too
    HOT ROD BOATS
    ANGIER, NC
    pump & parts
    fiberglass work
    s.s. hard lines custom made
    pretty much anything
    New Jersey
    Quote Originally Posted by terrytav View Post
    can you post a picture?
    Glenwood you must use with rail kit, the other is a 3 point
ID:	100707   Click image for larger version.
ID:	100708   Click image for larger version.
ID:	100709   Click image for larger version.
    Albuquerque,N.M.
    anybody make something nicer looking. if not i'll just cut my rails to clear the side mount starter. thanks everybody for taking the time to answer.
    New Jersey
    I refer you back to post #5. You might want to add Jack at MPD and Duane at Hi-Tech. They make some really clean rail kits with the optioin of a top mount starter. Ya need to talk to them, the top mount starter option may not show on thier web pages.
    edit: I see you already have a rail kit, these guys should be able to provide the requred parts to add the top mount starter to your stuff. Agian, talk to them and they will go out of their way to help you out.
    Doug
    if you already have a rail kit, buy the rear engine plate and adapter from lightning or JBP
    I made mine with an adapter purchased fron a forum member
    #55
    If you can, run a top mount starter...... My tunnel hull, the starter was lying almost on
    the tops of the tunnel, with Click image for larger version.
    std starter location. When
    I re-rigged, I moved the engine forward, and dropped it as much as I could, so no way a bottom mount would work, for me.
    B1 Racing cs19's Avatar
    How do you guys like the lightning top mount bracket? Is it any good? Can you adjust the up and down position on it? Is it true you have to run a 1/2" thick rear motor plate with those brackets? If so, why?
    Mine is 1/2"...I assume so the is more threads for the bolts that hold the starter stand on..I dunno. The only(s) way I know to adjust the up and down are....Jan will sell a .030 taller/higher starter stand...or with a set off offset dowls for the locating pins in the back of the block.
