Helmet restraint ?'s
Results 1 to 14 of 14
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Default Helmet restraint ?'s
    Quote Originally Posted by Jetboatguru View Post
    Avoid buying the helmet restraint device that Lifeline sells and have them sew the d rings directly on to your jacket and get the straps from them. It is a safer deal in my opinion as it cant slide up your torso in a crash.
    I am not questioning what Tony has said, but want to know what you guys think and have any of you guys went this route? I have often wondered about the band that wraps around the torso, and being that I dont have Titties or breasteses to help or interfere here, im considering having LL sew the d rings on the jacket and go this route.
    Any input?
    One more thing...Has anyone tried to get a hold of Lifeline in the past week or so? been calling like hell, I guess they hunker down for the holidays too?
    Todd
    Parker Az. / Burley Id.
    Lifeline always closes for two weeks at Christmas. Call them after new years.
    TRG
    TRG is offline
    Santa Clarita
    Todd...talk to woodz, he had them done on his jacket but pretty sure he didn't end up using them.
    Senior Member desrtrat256's Avatar
    San Diego, CA
    On the same note are there any APBA approved neck restraints? For exapmple Hans, Decel, R-3 etc. I know some are FIA approved without 5 point harness' which would make them ideal for boat racing but Im not sure if the APBA approves.
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by TRG View Post
    Any input?
    Todd
    todd, the old helmet restraint chest strap was only held together with velcro. the newer helmet restraint has a strap and d-ring that can be tightened up. i haven't seen the jacket d-rings you're talking about, but for me, i'm happy with the restraint. i have all the straps tightened up so they are tight with the chest strap basically under my arm pits.
    Todd-i have a spare set of restraints (lifeline) at the shop. lemme know if you want to use them. I think I still have an extra pair of medium ballistic shorts as well, unless I loaned em out and didnt get em back.
    TRG
    TRG is offline
    Right on Finne, You just shut down boff of my threads! like quick! thanks
    Senior Member Red Rocket's Avatar
    winchester, ca
    The biggest problem with the restraints is a lot and I mean alot of the guys are adjusting them properly. They are left way too loose. All the guys you see in the staging lanes with their helmets sitting on top of their head with the life jacket on are not adjusted properly. When your helmet and restraint are on you should have almost no movement of your head up and down or side to side.
    Senior Member 77charger's Avatar
    todd i have a pair of them also that i probbaly wont ever use again.Even have the d rings i took off my helmet so if you need them let me know.You can also use the ballistic shorts i have they are the skinny size.Would loan you my chute jacket but its out of date by 2 years its a skinny size too.I did have to get an extender the last time around though.
    B1 Racing cs19's Avatar
    Quote Originally Posted by Red Rocket View Post
    What he said.
    I didnt like the d rings attached to the jacket personally. Todd, I think you will be just fine with the deal finnegan has. Dont sweat any of this stuff, we will dial you in on everything and that goes for anyone that is thinking about racing for their first time, we can get you loaner gear or whatever you need. Just let us know.
    Senior Member bobbo541's Avatar
    San Ramon, Ca
    I have had my restraints sewn into my jacket since 2002 and i like it,one less thing to have to put on. My jacket fits snug so it shouldnt ride up on me. Once the restraints are attached to my helmet i cant move my head much.
    What he said.
    if you know anyone who will need to borrow ballistic shorts let me know i plan on being at all the races anyways.size 34s i think.
    Figure its another pair if nothing else is availible would do the jacket too but i aint paying for a cert right now.
    Todd you can have the restraints and D rings just let me know.they aint going nowhere just PM me leaving for glamis tomorrow so wont be back til mon.
    Mohave Valley/Quartzsite
    Couldn't agree more (except I'm assuming improperly?)!!!! With them adjust correctly, you shouldn't be able to get the helmet off your noggin without undoing everything..
    Special Thanks to:
    Nelson Speed & Marine
    D21 ENT
    J.J. @ Beaver Fab
    Performance Boat Candy
