Ratchet Release/Jet-a-way
Results 1 to 13 of 13
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Default Ratchet Release/Jet-a-way
    Hey guys, I am looking for a jet-a-way, and am pondering the idea of building one. I am just trying to not get another $1500 hickey, trying to get legal. Has anyone been down this road? I have a Southwind Tunnel and dont want to cut the boat for a Pop-Off.
    Kingman/Golden Vly, Az
    Jim Brock had one for sale & also, DuaneHTP sells them ...both are members on the boards...just sayin'
    FastRat
    first thing i would check with dwyane at hi tech and see if his ratchet is patented, next he sometimes has rebuilt units at a discount off retail. almost anything can be machined or reverse engineered, can you do it easily will be the question, to protoype a unit test it make the drive dogs or get them from casale i have my doubts that you could save much even if you donate an unlimited amount of time and labor. this product has a long history of working and my .02, in saving your life and or your boat maybe a small price to pay to use an off the shelf unit. just my opinion
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    I got lucky when we bought ours. Dwayne had a just finished a rebuilt one and we bought it. Used ones are about the same price as a rebuilt.
    If building one made sense we would have built one. The heat treated shafts and dogs etc will cost quite a bit just for one.
    QE 439 Twin Turbo
    bullhead city
    does duane make one for a 3 point mount where the bellhousing would bolt to it?
    I'm No Expert Shaun's Avatar
    San Clemente, Ca
    Quote Originally Posted by hihosilver View Post
    If you need a jetaway you probably need to get ride of that 3 point mount too...
    bullhead city
    I know but can only do the engine this year, next winter it will get stringers, I want the release so I don't have to run the pump to start and tune the new motor
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Save quite a bit of "cheese" removing the four bolts that connect the pump to the engine.
    bullhead city
    pain in the ass and I will need one anyway as I am putting in a 496, it's a mild build for now but old motor won't make another summer and I already have the crank and parts
    slightly "off topic" but to address Hiho's ?? ,Simple enough to turn 3 point (depending on the actual mount style) into a Jetaway compatible deal with a little engineeering , heres an example done last season
    bullhead city
    nice looking but I don't have any stringers yet, guess I will run it without this season, how much are duanes units, rebuilt and new, thanks
    Led
    Led is offline
    Jul 2010
    Yes, thats what I was thinking more time and $$ than it worth, I will call HTP, and see what he has. I almost bout another boat, and was going to take the release off it and try to resale it.
    Senior Member applekrate's Avatar
    Maricopa & St Johns, Arizona
    Quote Originally Posted by johnray069 View Post
    I do not think whether it is patented or not has anything to do with it. You can make or copy anything you want for yourself. Patents protect others from manufacturing and competing on the market.
    I bought as jetaway in '08. It is installed but, have not used it yet, hopefully have it in the water this year. Also like the neutral feature for firing up on trailer.
    www.pontiacheaven.org
    '72 Hondo Flat
    '74 Rogers jet
    Phil 2:11
