Tip on mounting a 5lb nitrous bottle.
Results 1 to 7 of 7
    Apr 2009
    Default Tip on mounting a 5lb nitrous bottle.
    Have any of you guy thought of mounting the sauce in the scoop?
    Just a thought.
    Pork
    Promoting pollution Smog Pump's Avatar
    Sep 2010
    Pumpkin Center, CA
    Sauce??????????
    Anything 80 proof or better will do me!
    Pump
    Southwest corner AR
    Quote Originally Posted by Pork&Bail View Post
    Just a thought.
    Pork
    Heat when sitting would be a factor to think about! I have seen 10# bottles pop the safety valve when covered and away fron the motor heat! WT
    WT
    WFL Crew!!!
    Apr 2009
    Quote Originally Posted by Smog Pump View Post
    Sauce??????????
    Pump
    What are you lame or something?
    Sauce=nitrous!
    Sep 2010
    Pumpkin Center, CA
    DUH! Just never heard of it referred to as SAUCE. Up here, we just call it GAS, or, Mr Happy Tank. .
    There are lots of guys up here that do that. Pine Flat and Kings River are full of em' in the summer. Makes Turds look like hero's when no one knows, but it sucks when you run out and your back to being a ho-hum Turd. Then EVERYBODY knows.
    It pays to check that scoop!!
    Pump
    okie, lake Texoma
    Not a good idea.If you have the very slightest leak in the nos system it will settle into the engine and you will blow the heads off of it when you crank it.
    H8-2-W8
    [email protected] first pass
    Anza Valley, Lost Lake, CA
    Doesn't matter if it's boosted with GAS or not. A TURD is a TURD either way.
    Lots of guys like that on the Lower River. If the boat runs WAY better than you think it would, its got a surprise hidden somewhere for sure.
    I heard of one guy that ran N/A(??) until he lost(with backfiring/flames). His wife said he "ran out of GAS".
    I never looked, but Im sure it was in the scoop.
    T
