what do you think??? olds 350 diesel in a jet boat??
Results 1 to 10 of 10
    Default what do you think??? olds 350 diesel in a jet boat??
    the way i see it the weight will be about the same a a typical big block yes i know im probly going to take a 25 mph hit in top speed it would be diffrent the only problem i can forsee is keeping water temp up as diesels need heat to run rite what u think?
    Aug 2009
    Missouri
    Converting it to gas or staying diesel?
    keeping it a diesel i just think it would be neat cause the boat gets all kinds of looks around here anyway (if you dont have a 25 foot cuddy boat u dont exisest around here) backing it down in the water firing it up and it rattles and black smokes i am a diesel guru anyway i got WAY too much momey in my cummins
    that engine was/is a POS, huge waste of time IMO
    #55
    Dallas, TX
    X2. One of the worst engines ever built. I would be surprised if you can even find one with the starter boss still intact.
    i heard the 1980+ ones were ok and yes they had head gasket problem just like any other oldsmobile engine
    Member aj06bolt12r's Avatar
    Feb 2010
    Middle Tennessee
    If you want a diesel jet boat why not a 4bt Cummings. They are capable of serious power. Or a duramax if you can afford it cause its probly lighter. You would need like a AAAA impeller to go anywhere lol.
    '78 nordic bubble deck, berkm a imp, place diverter, 460 with ported doves and oversize stainless valves, custom flat hyd cam, 1050 dominator, ect...
    Yucaipa, California
    A cool video on a diesel to gas conversion of an olds motor. This olds guy knows his shiat..mondollars should take notes.
    1992 Eliminator Daytona 21'
    Chantilly Va.
    Default 5.7 diesel...
    Quote Originally Posted by glastornjet73 View Post
    Have heard of wackiest...I had a co-worker try to have me transplant a 350 olds diesel into my OEM 396. Camaro 4 sp. Did it for one season for grins.Was very consistant.Actually tried it.Smoked like ten DIRTY MOTHER ****ERS....within .01 to .02 sec every pass in the 1/8 mi.all season . 69 degrees to 105 degrees in the heat. Varied .03 all year in a 3000 LB car all year long.
    One word: Turbo
    S CP
