Reverse Bucket Problem?
Results 1 to 13 of 13
    Southwest corner AR
    Default Reverse Bucket Problem?
    I have all new stuff cable,place diverter,lever! And when I am under speed the bucket will start to drift down and cause steering and water coming in boat problems! How can I tighten it up so it wont move under speed? Has anyone had to solve this problem befor? WT
    Coby
    Talking
    just put a kink in your reverse cable.
    I owed you that one....
    Senior Member GAWnCA's Avatar
    Sacramento, CA, USA
    Coby
    Have you got a photo of what you are talking about?
    Southwest corner AR
    Yes you did!
    Southwest corner AR
    I dont have a pix. of the pump with me! Everything is free (loose) and it moves to freely! WT
    re-clock the forward/reverse handle so that it can't fall down when in the forward position. its a pretty common problem.
    Southwest corner AR
    Are you saying change from like 12 to 4 position ?
    Widetrack most fwd rev controllers use nyliners for smooth operation and also have a "wavy washer" to tension (often missing) The Wavy helps keep the handle tight, check it out ? if its not there call me i'll give you one . If the bucket is adjusted correctly (out of the path of the exit at WOT) shouldn't happen ! lets see a pic otherwise ! Tom
    PS You could also consider a three position locking type handle
    Southwest corner AR
    I will check this out tonight! Thanks for the info. WT
    Coby
    Santa Clarita
    Coby
    I had that problem and just switched to a shifter with a detent. Problem solved.
    http://www.rexmar.com/page39.html
    ....like warm apple pie RaceFace's Avatar
    Mission Viejo
    Exactly. Mine would pop into neutral half way into plane. What a pisser! I bought a new reverse handle with a button on the handle so it would lock into 'drive' and 'reverse'. Problem solved.
    Or just hang onto the handle until you are on plane and going. I did that for years....then got sick of it.
    Race
    Sacramento, CA, USA
    So which one did you buy?
    You can also fashion a return spring to the controller to make it "spring loaded" in reverse and return to forward Tom
