Headers ??
Results 1 to 12 of 12
Headers ??
    Member steveo-85's Avatar
    May 2010
    Ada,ok
    Default Upswept Headers on Jet ??
    Has anybody ran a set of upswept dragster headers? Will they clear on a Bahner with factory pump and engine location and will they be legal to run being Dry and all? I think they would look pretty good. Anybody running them?
  2. #2
    Silverdale, Washington
    What kind? I ran Borlas for a while. They softened the bark of my blower motor but it was not exactly "legal".
  3. #3
    May 2010
    Ada,ok
    Yes , I really like the look of the Polished Stainless Borla ones .
  4. #4
    Here's a shot of when I was running them. I needed to slightly move the motor forward a touch but otherwise no problems fitting them.
  5. #5
    Senior Member lv4jetboats's Avatar
    fernley nevada
    fernley nevada
    These headers are shoenfield not bad for the price.
  7. #7
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Dont know where you reside, but I have a set that you are more than welcome to dry fit if you are near the Pomona area.
  8. #8
    Senior Member hot-rod 21's Avatar
    Apr 2009
    se michigan
    I have run the borlas as well for a couple seasons, they do look good but I wouldn't recommend you buy a set unless you get a smokin deal on them. Because they don't seem to hold up very well, the inside of the mufflers break apart. Just my oopinion.
    SAMSPARTS.COM
  9. #9
    May 2010
    Ada,ok
    Quote Originally Posted by TRG View Post
    Thank you for the offer and i would take you up but im in oklahoma.
  10. #10
    May 2010
    Ada,ok
    Quote Originally Posted by hot-rod 21 View Post
    They do look good, What they cost i want something that will hold up.
  11. #11
    Senior Member blownsouthwind's Avatar
    surprise,AZ
    Default headers
    I have had no problems with mineClick image for larger version.
  12. #12
    Quote Originally Posted by blownsouthwind View Post
    Nor mine but I will qualify that in that I got them used and had no problems with them. I then traded them off (going TT) and heard that that guy blew them out but given his setup/tuneup, the ceramic tiles off of the spaceshuttle wouldn't have held up.
