Best water jacketed headers?
Results 1 to 8 of 8
    Member kahuna's Avatar
    Oct 2010
    Folsom, CA
    Default Best water jacketed headers?
    Any suggestions on the best set up for water jacketed thru hull headers for a BBF?
    Paul
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    Sent you a PM
    Norco
    You building your motor? Already built?
    I went with Blue Thunder heads due to the Chevy Exht flange. I run Lightning Headers.
    Junior Member 71rcb's Avatar
    Paul -- you'll find more options w/ the bbc headers or manifolds. Lightning or CMI sells an adapter plate to use on the stock bbf port if you are not using one of the aftermarket heads with the bbc style port.
    As far as which one is best ... well you know what they say about opinions. I have some coated mild steel Lightings that appear to be well made. They are still looking good (appearance and structurally) at 10 yrs old. FWIW
    cheers
    Corey
    Quote Originally Posted by danhercules View Post
    Confused tug boats dont count!!!!
    Oct 2010
    Folsom, CA
    Default Headers
    Motor is already built. BBF punched and stroked to 512. Dove C headed porter.
    Not sure I understand using a chevy flange fornthe headers. Doesn't lightening make polished jacketed headers? Or anyone else? HTP?
    Paul
    lightning makes some very nice all (inner and outer) stainless fully polished $$$
    When I get the coin I will have a set
    #55
    Norco
    Quote Originally Posted by kahuna View Post
    Paul
    Lightning I dont think make headers with Ford flanges. You need to run an adapter. My heads are BBF, but the bolt pattern on the exht is Chevy, so I can run Chevy headers.
