Want bigger Roost
Results 1 to 14 of 23
Want bigger Roost
    Member steveo-85's Avatar
    May 2010
    Ada,ok
    Default Want bigger Roost
    I have a 78 bahner with a 12 JC pump. Stock pump with new Place Diverter. Wanting a bigger roost. Whats my opions or whats the trick. Do i Change the bowl and you a drop snoot and a wedge or a rooster booster? Or is there another way without breaking down the pump? I am very mechanical minded and can handle taking it apart but just want to know what to expect or would it be a mistake to break it down without rebuilding and what awould i need?
    thanks
    B1 Racing cs19's Avatar
    Best route is to get a split bowl and maybe a droop, try it again if thats not enough you can play with wedges, that should get you a big enough roost. If your one of those guys that has to have a giant roost (why?) then you have to modify the place diverter. Try and avoid that one.
    Mar 2010
    Clarksville, TN
    Ya what he said
    Got this with a droop and 4* up wedge
    Sep 2008
    OC, CA
    Again, why???
    "I'm just SPRAYIN' man!!" '78 Crusader's Avatar
    Oct 2010
    McKinney, Texas
    Quote Originally Posted by steveo-85 View Post
    thanks
    Stevo, we're sort of neighbors...you should come down to Texas sometime and hang with us in Lake Lavon.
    I have a similiar set up as yours and without spending a lot of money, I was able to get a larger roost by making a few modifications. I'm not real technical with all the component names so bear with me.
    In order to get the diverter to go higher, we had to use a grinder and grind away a small amount of material on the mount where your diverter cable is attached to. Then you'd adjust your cable to allow for more movement of the diverter.I was able to increase the size of my roost. Here is a You Tube link to show you.
    Cliff
    1978 21' Crusader, 466 CID BBF, Berkely Jet
    1966 13' Boston Whaler sport, 40 HP Yamaha Two Smoker
    Maple Ridge B.C. Canada
    Quote Originally Posted by cp562 View Post
    Again, why???
    THEY LOOK COOL
    We know it's a waste of power, but it looks cool,like a polished tunnelram when 5500 or 6000 is all your gonna rev anyway, or huge fake boobs. kind of useless,but there great to look at. I'm gettin a droop snoot this winter ,few mph more ,but I'm hopin to be able to spray our local commuter train on the bridge this summer It's all about havin fun right!
    May 2010
    Ada,ok
    Thanks to all you guys that replyed, I just want it bigger because i enjoy cruisin around the lake and showin off... Havin fun is what its about to me since i dont compete or anything. I just want it bigger.
    How involved is changing the bowl? Do i replace anything like gaskets or somithing? I See how the bowl comes apart but what is involved in swapping the bowl ? What do i need other than the bowl and droop?
    Sorry for all the questions.. I build engines and Drag cars but never been in a pump.
    Heres a pic of what she can do right now. Ive seen worse
    May 2010
    Ada,ok
    Quote Originally Posted by '78 Crusader View Post
    Ya. Keep in touch. Ill try and get that way this summer or you guys should come to
    Mcgee Creek Lake. Its awsome. Im always the only Jet here so it would be nice having some more around for a change.
    thanks for the reply
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    its no big deal dude. I was a little nervous about it too. I have mine apart right now for some upgrades. If you want I can text you some pics this weekend.
    May 2010
    Ada,ok
    Quote Originally Posted by Bodean's Hammer View Post
    Hell ya.. That would be great if you get time..
    When i unbolt the bowl does the bowl just slide off the shaft leaving the shaft and impeller
    behind of does the shaft need removed.
    Any bushing of shims to worry about.
    THANKS for all the help
    From the pic looks like a pretty good tail
    Yep. Do you have your transome adapter off yet?
    May 2010
    Ada,ok
    Nope.. Boat still has the cover on it. Wanted to see what was involved before i began. Its prolly alot easyier than im making it.Just didnt want to tear the sh:t out of things and then haft to put it back together without changing anything. Man im ready for summer. The sqeeze and I will come up and hang out and have a cold one. From looking at the pics you guys have alot of sick boats up there.
    I know TX19 has a really nice berkeley split bowl for sale, might shoot him a PM, I think hes got a droop too. Not sure. Adding the bowl and droop is very simple, 2 gaskets and thats pretty much it. We could guide you through it. You would fur sure have a much differnt handling boat with a droop so make sure a droop is a good call for your application. What hull is it? What kinda HP?
    CS
LinkBacks (?)
