418 steppin' it up for 2011
Page 1 of 15 1 2 3 4 11 ... LastLast
Results 1 to 14 of 199
    B1 Racing cs19's Avatar
    Default 418 steppin' it up for 2011
    2 stages of Edelbrock spray to start with. Outside kit is titanium E3 annulars, inside are E2 90's.
  2. #2
    Senior Member Mike D's Avatar
    Anaheim/Aha
    Nice you going to run 300 hp ? 150 per system? Nice job Looks good
  3. #3
    corona ca.
    Default steppin it up
    well thats looks awesome. Good luck with the rest of the build. Are you going to make the March race?
  4. #4
    Anaheim/Aha
    Quote Originally Posted by av137 View Post
    Are you going to make it?
  5. #5
    Senior Member INTHERED's Avatar
    Apr 2010
    Rancho Cucamonga
    Looks awesome. Can't wait to watch that thing run this year.
  6. #6
    corona ca.
    Quote Originally Posted by Mike D View Post
    yea, i'll be there....Elsinore?
  7. #7
    Doing everything I can to make it. Got some help from Cp/Carrillo and Edelbrock so that helps alot. New Sonny Bryant billet crank, 5 stage drysump, dolly trailer, etc. So I've got a long way to go but I'm trying real hard and I'm planning on being there.
    Mike the inside kit maxes out around 300 maybe 350 outside can go 500 with these solenoids, it's there if I want to get after it but I'll take it easy first part of the year, at first I just want to play around with using 2 systems and try a few things.
  8. #8
    Senior Member Pattymelt18's Avatar
    Looking good. Big fan of the soft line.
  9. #9
    Member MAFIA'S-PGE's Avatar
    Default nice
    well hurry up! you better be there boat in hand
  10. #10
    Senior Member ULTRA 23's Avatar
    Corona, CA
    Looking good you will make it.
    John D
    INLAND ULTRA CUSTOM BOATS
    Corona, CA
    951-734-6000
    Ultraboats.com
  11. #11
    member
    Nov 2008
    Thumbs up looking good
    Looks great, always top notch stuff you do. Good job. What are the plans for two guns If you don't mind sharing? Leave on one kit, boat takes good set fire the other kit?
    or leave on one kit and leave the other kit available for a beam race? Like dealing with hydros. Thanks in advance. keep up the good work Scott King
  12. #12
    Shell Knob, MO
    Nice clean lookinig set up. Chris.
    Duane HTP
  13. #13
    Quote Originally Posted by Scott King View Post
    I definatly wont be fender racing with it. We set up the timers in the pits and then go run it, can't change it one we go in the water.
    Ill leave on no kits just motor then bring on 1st stage then shortly after both stages then drop one stage and finish on one stage to keep mph down. I want to get my half track times down as far as possible. Should be 4.1s with no trouble, been running 4.2s so I think it's totally possible. 4.0s seems like stretch for the weights I'm dealing with. Should run the number at SITC also if we make the trip out.
  14. #14
    Doing everything I can to make it. Got some help from Cp/Carrillo and Edelbrock so that helps alot. New Sonny Bryant billet crank, 5 stage drysump, dolly trailer, etc..
    You keeping the same cubes ?
    Sounds like it's going to be stought.
    S CP
LinkBacks (?)
