water psi on suction
Results 1 to 6 of 6
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Default water psi on suction
    Im buying new gauges for the swtd and was wondering what range gauge should i get I've seen oil psi gauges used and the such. Autometer makes a water psi gauge that goes up to 35 is that enough?
    Not sure what kind of pressure you will see with a jet. I put one in my Eliminator after losing a raw water impeller to hydrilla sucked around the water pickup.
    Mine shows just under 5 lbs at idle, and in the 13 to 15 range at cruise rpm.
    Larry
    62 Bel-Air 409
    260 Eagle XP HP500EFI
    2016 Corvette Z51
    Remember in November
    Well done USN Seal Team 6
    okie, lake Texoma
    you should try to find a 0-100 guage. JMHO
    H8-2-W8
    [email protected] first pass
    Impeachment! 75 TX's Avatar
    Culver City, Ca
    I used an Autometer Blower gauge with good success. 0-60 psi. The one on the left.
    Quote Originally Posted by HBInHeat View Post
    Personally I'd get something that allows for a higher range , we have used oil pressure guages with good sucess
    Josh used these liquid filled Marshalls recently too
    sacramento
    the faster you go the more suction pressure you'll run usually . if you start messing with the hardware you'll probably be tuning @ 15-65psi depending if you race or not(from what i've heard). i'm only at 45psi . but if you land the thing on a shut down you can see if the pressure spike if you have a 100psi.thats what i'm running & i got the gauges at a hydrolic store . chrome bezels, white face, liquid filled $14 each. i think most guys that blow the suction pieces apart get spikes @ 100psi.(standard berkly stuff)
