Thrust/Bowl Bearing question
Results 1 to 3 of 3
    Senior Member sleekcraft137's Avatar
    Star, ID
    Default Thrust/Bowl Bearing question
    Im doing some winter projects on my boat and had a question about the jet. How freely should the pump shaft turn?? I disconnected the drive line from the motor and tried spinning it. It will turn with no noise, however i cant just spin it and watch it spin if i let go. I have to apply a little bit of force but not a ton......makes sense?? I would say that my 5 yo could probably turn it but not very well. Im just not sure how loose its supposed to be.
    And the new project begins!
    B1 Racing cs19's Avatar
    Quote Originally Posted by sleekcraft137 View Post
    Perfectly normal, your ok
    Star, ID
    cool thanks for the help, anything else i should be looking for?
