How does this bolt up?
Results 1 to 7 of 7
    Aug 2010
    Default How does this bolt up?
    I bought a hardin marine bbc alternator bracket... just trying to picture in my mind how it bolts up...
    Bolts to the lower right front of the engine, usually used for motor plate mounting.
    Aug 2010
    yeah i got that much... the 2 holes in the large bracket bolt to the block... what about the adjuster arm? eh i guess ill just toss it on there and see what happens.
    Southwest corner AR
    Quote Originally Posted by ka0tyk View Post
    The top bracket goes to a hole on the head!
    WT
    WFL Crew!!!
    Senior Member Hustler's Avatar
    Tujunga,ca
    You will most likley need to make a spacer to adjust it out
    Member 1980NORDIC's Avatar
    Las Vegas
    i was looking at that and thinking it is perfect for your app, because you have a cradle mount if im not mistaken.
    1980 Nordic
    1984 Tahiti
    Aug 2010
    got it in... just needed to open up the hole on the little adj arm to fit the bolt. it was filled with powdercoating and thats why the bolt wouldnt go through. now it all makes sense.
