Flo Coating jet boat floor ????
Page 1 of 4 1 2 3 4 LastLast
Results 1 to 14 of 48
    Atlanta TX
    Default Flo Coating jet boat floor ????
    Need imfo on flo coating the floor of my Daytona. Where to buy it , how to apply it etc... ?
    Thanks Rick
    " Live Laterally " Dominator's Avatar
    Phoenix
    pm TRG or Riverdad.
    " NO MOTOR NO BOATER "
    " I'd rather be riding in my boat thinking about God, than in church thinking about my boat ".
    Dec 2010
    Alabama
    Thats a good question to have answered on the forum. I need to know the same thing.
    How do you flocoat and what do you use.
    High Performance Marine ARS Marine's Avatar
    Feb 2009
    Morris,Illinois
    Just went thru this the past few weeks.
    I Purchased Valspar "flow Coat" 5782C90002 . Be Careful the stuff goes bad Very Fast!!
    I've used this product about 5 years ago and Loved it. I'm sorry to say that my love has changed after talking with TRG he turned me onto some Prestec available from Shurfab.
    Stuff is nice and easy to work with, kicksoff with MEKP. Cleans up with Acetone.And after hardened it's SUPER Clear!!!
    What I've always done as for prep work is 80 grit the floor then come back and 180 grit everything. The prestec must be sprayed on. I've tried a brush and does it look like $UKIn *hit.
    Are you just re Flow coating your floor, or are you removing the carpet and changing the look?
    TRG
    TRG is offline
    Senior Member TRG's Avatar
    Sherfab unlimited in Ontario Ca Sher-Fab Unlimited Inc. Your First Choice For Composites they mail order product.
    Pretty much clean 100% of dirt, grime, oil, glue...... EVERYTHING from the hull!
    Sand until desired flatness for finish, essentially you need to mix the Prestec (I recommend this brand, its pretty much a problem free product!)
    roll, brush or Spray it down, it will cure in open air and no PVA (Poly Vinyl Alcohol) will be needed for 100% cure, The manufacturer does not reccoment adding anything for thinning, I have added very small amounts of Acetone in the past (Less than 5-10%) and never once saw any issues, this product as well as the Duratech can be wet sanded for an even flatter finish such as clear on a car, but a very hard surface! so you may want to use a very fine paper before buff to make it easier on you and your knees.
    I blasted through this rather quickly, so if I get anything wrong as the internet pro's pop in, please accept my deepest condolences for my Laziness, if there is any more questions, you can get more info from Ron at Sherfab, he will sit on the phone with you and paint a much prettier pic for you, after all, he'll be getting the sale! Their prices are pretty hard to beat these days.
    TRG
    Senior Member wildstreak's Avatar
    Feb 2009
    East Texas
    Default About time we get this answered
    We have all been talking about it around here. I am about to look and see if they have a website.
    Thanks for the info
    Member 08VMax's Avatar
    Jan 2011
    Benicia, CA
    Nice thread, my Hondo had carpet that I didn't like. I've torn some of it out, the floor is an "unfinished" floor. They were planning on carpet during manufactering (sp?) process.. I'm just clean it up for now but next off season I wanna finish up nice..
    Feb 2009
    East Texas
    Default contact info
    Email them with questions to [email protected] or call at 909-923-2200
    And who puts carpet in a performance boat?? just wondering
    Feb 2009
    East Texas
    Quote Originally Posted by ARS Marine View Post
    He is just making his Daytona look new inside, it has had a little rough use from the previous owner. I just want to make mine look fresh too.
    Sher-fab is a great source X 5 for Prestec clear, it sprays just like auto paint, that is the beauty of it!
    Atlanta TX
    We talked to A.J. today at Sher fab & he said to just pour it on & spread it with a spreader. Anyone ever done this ?
    for flat work maybe, keep in mind the thicker the coating, the more prone it is to cracking. Cheap HVLP gun with the biggest nozzle you can get, cover everything you don't want painted, with tape of plastic, and have at it. It's for giving as far as runs, or sags, but it will if applied too thick. Three coats is plenty of thickness, the smoother the starting surface the better the result. The Prestec recomends a minimum tooth of 220 to adhere.
    Jan 2011
    Benicia, CA
    I just finished glassing in the new toe kick with West System.. I also used West System's #405 Filleting Blend Filler to thicken it up, that's the brown color seen in the fillets.
    I was gonna sand it down to where it's smooth and looks better then spray some thinned down Epoxy/Hardener straight mix (no filler) through a cheapo Harbor Freight primer gun to get a nice "flow" like finish.. This is what I was recommended to do by the local V-Drive race shop in my area, I trust the guy a lot, but is there other products made better for this situation? The plywood is already sealed with a straight Resin/Hardener mix just poured on, it's about 1/16" to 3/32" thick.
    I guess my question here is would this Prestec stuff be a better choice? Will it run on a vertical surface?
    Thanks, Matt
    Feb 2009
    East Texas
    Default got some on the way
    Ordered some on Monday, will be here by end of the week. So yall think spraying is best? I have a hvlp gun that aint doin a thing.
