79 tahiti or 75 fantasy
Results 1 to 14 of 24
    The Brown Bomber oldmudwiser's Avatar
    Apr 2010
    apple valley ca
    Default 79 tahiti or 75 fantasy
    a friend trashed my boat last summer and he replaced it with a 79 tahiti. its got a 12jc blade and a solid bowl with a jetovator. my 75 fantsy has an A pump and a split bowl, with a place diverter. so im wonder what to do?? try to fix the damage or build the tahiti? please help...
ID:	103701Click image for larger version.
Name:	2010-09-20 16.21.33.jpg
    Member bubbledeck55's Avatar
    Oct 2010
    bullshit city az
    switch the pump and motor into the tahiti best bet
    Apr 2010
    apple valley ca
Name:	2010-09-21 07.54.08.jpg
ID:	103726Click image for larger version.
ID:	103719Click image for larger version.
    im moving back to apple valley ca this week and was hoping to find a good jet guy.
Name:	2010-09-21 07.54.01.jpg
ID:	103711   Click image for larger version.
Name:	2010-09-20 16.21.30.jpg
ID:	103712   Click image for larger version.
    Apr 2010
    apple valley ca
    Quote Originally Posted by bubbledeck55 View Post
    is it just the repair or is the tahiti a better boat?
    Apr 2010
    apple valley ca
    the fantay did about 68mph with a built 429 around 470hp
    Apr 2010
    apple valley ca
ID:	103740Click image for larger version.
    do i need to take all the pump out and the intake? or can i just do the prop and the bowl?
    Senior Member sleekcraft137's Avatar
    Star, ID
    JESUS CH$%ST WTF did he do to your BOAT???? The nose is all muffed, the cap is separated, the motor is in the passenger seat......???
    And the new project begins!
    Senior Member PonyFiveO's Avatar
    Feb 2009
    Southbay to the Central Valley
    The lines on the Fantasy looks So Much nicer. Do either boats have full stringers?
    Apr 2010
    apple valley ca
    well the boat hit a wal of a rock. he paniced and let off the gas. broke both engine mounts in half and put the engine in the back seat. the boat went down with the motor. i got it all out though, rebuilt the motor and now its on an engine stand.
    nither boat has full stringers.
    Senior Member jyeager's Avatar
    Sep 2010
    West Covina, California, United States
    i would go with the tahiti. fantasy is going to cost a lot to fix.
    Just Me snoc653's Avatar
    Eastern Iowa
    The Fantasy looks to have had a bow tank. If the Tahiti has standard side tanks it should handle better. I think the Tahiti would make an excellent substitute for the damaged boat and that your friend went so far as to find it for you is a really good thing. Most would have told you to file it on your insurance as it was an accident. Yes I know most of us don't have insurance on our boats.
    Building the Tahiti should be one of the moments that 40 yrs from now you and your friend still talk about. There is more to boating than just the boat itself.
    Apr 2010
    apple valley ca
    so can i just swap the pump and not the loader? i would rather not deal with seting the loader if i can help it.
    Somewhere between Paso & L.A.
    yes-gravy job-pull the transom plate, unbolt the pump from the intake, and remove!
    couldn't get any easier
    Oct 2010
    bullshit city az
    pull the tahiti off the single place trailer and put it on the tandem, and you can swap pumps out without pulling the intake as long as it is the same pump... its not to much of a chore, just make sure to get all the gaskets... good luck
