motor plate mount blocks?
Results 1 to 14 of 28
    Default motor plate mount blocks?
    I had a brain fart when making my motor plates and didn't allow enough height for the standard plate blocks. the blocks are 2.5" tall and would stick up past the plate and look like crap. the blocks that bolt to the motor plate and angle iron. Last resort i'll have to make new motor plates (PITA). anyone use anything else besides the $25 a piece blocks from rex or cp? Pics would be appreciated.
    heres the blocks
    use a piece of bar stock of the size that you need and polish it, counter sink the socket heads into the block, looks good
    Quote Originally Posted by johnray069 View Post
    i thought about doing that but wasnt sure if it provided enough support
    also jan at lightning makes a lower profile block you might consider, the web site list them at 40 ea. i have made these blocks before and can now appreciate what they cost.
    We make some that are 2x2. Pm me your email and I will send you out some pics.
    Ladera Ranch
    Remake the plates and buy the rex blocks. The hard part is done, making new ones will be a lot easier now that you have a good template. IMO the square blocks people use are ghetto.
    B1 Racing cs19's Avatar
    You might get away with smaller pillow blocks but you may have to start over unfortunatly.
    Dont go ghetto on the pillow blocks, they are important parts of the motor mounts and your install looks real crappy when you cheap out here, just my .02.
    Also be aware that the blocks from rex are cut with no angle but the holes are already drilled so the hole will not be square to the angle you must machine on the pillow block, just another obstacle of building your own rail kit. I still use the Rex blocks sometimes but you have to correct the hole one way or another, your going to need a milling machine to do the job.
    Good luck.
    Ladera Ranch
    You can buy some spherical washers from McMaster to solve the hole angle issue that CS19 referred to...
    California
    I believe you could make it look clean and custom using some thick bar stock. I'd start out with 2x2 blocks 1.25" or so thick and profile the upper corner to fit the shape of the plate. Angle milling the base would most likely be necessarily, another nice touch would be countersinking allens into the blocks. However all this would require assess to a mill, as previously stated.
    Dare to be different, if it turns out great you can claim you planned it that way. Heres a quick 2D drawing.
    now that's siggy material
    Not sure taking up 4 degrees with a spherical washer is ideal, just re-machining the hole at the correct angle by going one size bigger is a better way to go IMO.
    Ladera Ranch
    Fair enough, seems to be working ok for me though. If you cut the block to match the plate angle don't you still have a problem with either end of the fastener not entirely meeting the surface of the block or plate? Are you counterboring the block too?
    The Earth
    Blog Entries
    24
    If there is enough interest I'll be happy to make some blank 90º blocks, without holes, on our next run, which isn't too far off. Then you can machine an angle of choice and drill hole at angle and size of choice. Just a thought. Production parts are always cheaper than one off's.
    Ya I spot face it on the inside after I machine the angle on the block, this way the bolt head and washer sit perfectly flat. Hard to explain but Im sure you get the concept.
