rogers mini day cruiser
Results 1 to 7 of 7
    Short and stout nunes792003's Avatar
    Nor Cal
    Default rogers mini day cruiser
    just bought a rogers mini day cruiser. Full stringer boat. It has a berkley 12jga in it. I have a question about the jet. It is suppost to be new and at idle it makes a grawling noise. but when you give it a little gas it goes away? any ideas? thanks for the help.
    B1 Racing cs19's Avatar
    Quote Originally Posted by nunes792003 View Post
    Normal if it goes away, if it doesnt go away you got a Thrust bearing problem. The noise your hearing is the driveline
    corona calif
    Default Rattle
    Generally this is caused by the relationship between the driveline yolk and the pumpshaft. Over the years the yolk and the shaft have worn and the clearance's have become slightly excessive and they will rattle at idle as soon as you apply throttle the splines lock up against each other and the noise goes away. This problem can be magnified if the pump has a SS impeller. Generally the driveline will rattle and the front bearing will whine and grow louder under acceleration.
    Senior Member Hare Pie's Avatar
    Redding, Ca
    I like to start out slow and then taper off.
    Nor Cal
    Quote Originally Posted by Hare Pie View Post
    what do you mean by this hare pie? money eater?
    Thanks guys for the info as this sounds right. Its coming from the drive line area. Thanks again. Don't know much about this boat. I will post pics it is almost like a tunnel hull with big notch outs in the bottom. Does anyone know much about these boats?
    so how would one go about fixing this problem? what parts need to be replaced? i have the same problem with a berk. started to annoy me last season thinking i should fix it before the next
    corona calif
    Quote Originally Posted by oldskoolpwr View Post
    Generally the yolk is the problem so by just replacing the driveline yolk will solve the problem. If you decide to replace the yolk, install the yolk on the pump shaft and see if you still have excessive play if you do then a pump shaft might be in you future!
