What's the best hull for a PGJ
Results 1 to 14 of 95
    Texas
    Default What's the best hull for a PGJ
    I'm going to build a boat to run PGJ and just wondering what you guys think is the best hull for that class/hp. I was thinking of CP tunnel, Cheyenne, placecraft or a warhahk '16 (remake of a texas tunnel) I know there's alot good boats to choose from just wondering which will be the fastest with a limited amount of hp (1100-1200hp). Thanks
    Pro Gas Jet RedPearl's Avatar
    Ausitn, TX
    Default pgj hull
    Wildercraft !!!
    Don't be afraid to try something new. Remember, amateurs built the Ark...Professionals built the Titanic!
    Texas
    Quote Originally Posted by RedPearl View Post
    Wildercraft !!!
    I tried to buy one off of Sleeper CP, but he wouldn't let it go. I really like those new Placecrafts like RacerJ's and Wood's but i don't know who made them, would love to know though so i could give 'em a call.
    So cal performance 19 stealth ( tpr ) It will out run them all. Give Greg a call at gs marine ( 951 ) 272-6060
    Renegade jet tunneljet's Avatar
    Shorewood Il
    How about a rogers dragstar.
    Senior Member bp298's Avatar
    LHC
    Quote Originally Posted by Filucky View Post
    why??? what happened to the twinturbolove????
    the quickest pgj in the country is still a cheyenne. the fastest was a daytona. both hulls in the 360-370lb range, and both (especially the cheyenne), a tad over 1200hp...
    Texas
    I picked up another set of worked over C460 heads and i still have the pistons, rods and crank to build a 9:1cr 598 to put the turbos on if i want down the road, but I want to build a PGJ just because it's a reall art to make a 500" n/a motor make big power under 7500rpm.
    Senior Member Racer J's Avatar
    Visalia CA
    How quick do you have to run to be competitive in PGJ?
    San Diego, CA
    Thumbs up
    Quote Originally Posted by Racer J View Post
    Current NJBA record I think is 8.37 at 127 mph. Class limitations are 515 Cubic inch Max. No nitrous.
    Keith Zellmer in Risky business years ago ran PGJ with a daytona and ran very well.
    A light boat, aluminum motor, light weight driver, efficient pump and a spread port motor spinning some rpm should be impressive in that class.
    Boat 405.
    Texas
    I'm thinking hi 7's.
    Thanks for Tom's number, i talked with him for about 45 min or so earlier and he seems to know his shit. I'm about 95% talked into getting a Placecraft from his new molds his finishing up.
    Ada, Michigan
    I want to build a PGJ just because it's a real expense to make a 500" n/a motor make big power under 7500rpm.
    Fixed it for you
    Senior Member PCE680's Avatar
    Manhattan Beach,CA / LHC,AZ
    Head over Heals/Cheyenne = 7.70's at Firebird.
    Texas
    Thats great news! I thought i seen where a few of the boats were running hi 7's, they must be running in both PGJ and UBFJ maybe? Where they can use some spray.
    Boat will be light, Great pump and a 500" BBF with prostock hemi heads. Down side is it will be a A460 steel block and i'm about 250lbs.
    Texas
    Quote Originally Posted by PCE680 View Post
    Shit!
LinkBacks (?)
  1. 03-07-2011, 08:09 AM
  2. 02-17-2011, 01:26 PM
