quick easy question...rail kit length
Results 1 to 6 of 6
    Sep 2009
    Chicago, IL
    Default quick easy question...rail kit length
    What is the length on the rails in rail kits for BBC? How many mounting holes through the stringers usually, and how far apart?
    Each kit needs to be made for the application
    IMO
    Sent from my iPhone
    #55
    B1 Racing cs19's Avatar
    Quote Originally Posted by PowerAddict View Post
    You can do a 32" rail, thats pretty short. Bolt spacing is up to you, if you already have holes in the stringers try and pick those up.
    the length may vary per application, but here is one that i use.
Name:	Rail Kit - Rail Kit L Bracket.jpg
    Silverdale, Washington
    Mine in the Brendella are 48" but the UFO II is 106" and I kick myself for not making my Brendellas that long. The long ones give a great solution for mounting seats, ect....
    Iff'n I was to do it again (and I may some day), I would go the longer the better
    The Man cordog009's Avatar
    East Texas
    I'd probably run them all the way to the front seats, would make mounting things alot easier and you can make cutouts whever you want to lighten the weight even more.
    1984 Youngblood TX-19 SOLD
