lube for pins on droop?
Results 1 to 8 of 8
    Maple Ridge B.C. Canada
    Default lube for pins on droop?
    puttin on my new droop snoot,wondering what kind of lube should I be using on the pins & bushings ,if any? thanx
    Senior Member watergun4u's Avatar
    Visalia, California, United States
    Quote Originally Posted by rogerroost View Post
    None really needed, when it's in the water, that lubes it, but you can use a little blue grease if you like ,won't hurt!
    I replaced my nylon sleeves and put a small amount of red grease on the pins.
    Made In The Shade
    Custom Window Tinting
    They are designed for water as lube, grease will only suspend any sand or grit causing premature wear.
    Concord, CA
    Default lube
    Any lube put on would be washed out during the first use. and leave a mess if any stays and collects dirt.
    Jerry
    I never had any sand, dirt, grit or mess on mine. The small amount I put on them is still there.
    Made In The Shade
    thanks guys,a bit to assemble.then I won't worry about it.I thought maybe there was some waterproof grease guys found that stuck around
    permatex anti-sieze compound. If (and I imagine you are) using the nylon sleeves and ss pins this has seemed to hold up best for me. No matter what you use, it will get blown out after time but the controls will tell when to re-apply. M
