new shift cable install question
Results 1 to 9 of 9
    Jul 2009
    Default new shift cable install question
    I just put a new teleflex 43 bc cable in my ultra. the problem im having is that it seems too loose. the boat resorts to reverse(gravity from the cup) and wont stay in nuetral or forward. is there a way to adjust the stiffness? any help would be appreciated!!
    Shell Knob, MO
    There is supposed to be a waffle washer on the pivot shaft of the shift lever. It puts tension on the pin to hold the lever in place. If it is weak or missing, it will cause your problem. One other way to solve this is to buy one of the billett shifters with a detent to hold them in place. Such as;
    http://www.eddiemarine.com/store/car...l&p=14112&c=76 or http://www.rexmar.com/page38.html
    Duane HTP
    Morgan Hill
    Also, to add to what Duane states, sometimes the shift lever is installed improperly, there needs to be squeeze tension on the wave washer, many times the lever is locked down to far out from the flange (if you have the Morse type lever that is)....
    GT
    Screamin SeaMonkees Schi-502's Avatar
    Vacaville, California
    Default Friction ring
    I have a friction ring on my shift/throttle lever. It's pretty cool.
ID:	105837   Click image for larger version.
    Loose, the Dogs of War!
    Jul 2009
    is this the washer that isnt flat?? or the plastic pieces? yes it is a morse.
    Shell Knob, MO
    Its the washer that isn't flat.
    Duane HTP
    Jul 2009
    where can i buy that friction ring or a new washer?
    Shell Knob, MO
    Sometimes you can find one at a hardware or industrial supply store. This is what they look like. Just find the right size.
    McMaster-Carr
    Then click on Disc Springs.
    Then click on Wave Disc Springs.
    Duane HTP
    Just for reference, I measured one from a spare shifter.
    Inside diameter = 0.762" (has to fit over a 3/4" shaft)
    Outside diameter = 1.250" (smaller would work, larger probably wouldn't)
    Thickness = 0.020"
    Amount of curvature = approximately 1/8"
    Since Rex Marine makes their own line of shifters, you might contact them to see if they use a similar item.
