Carpet glue
Results 1 to 7 of 7
Carpet glue
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Default Carpet glue
    Anybody know if a gallon of glue will be enough to lay carpet in a 18' jet. Floor , toekick, and beside the motor outside the stringers? Thanks
    Kingman/Golden Vly, Az
    IMO, i would think it would be more than enough!...on the can, it should tell you how many sq ft it will cover & also if you can thin it down ...i personally used 3M spray adhesive & it worked fine ...just sayin' my .02 cents
    FastRat
    Aug 2010
    Albuquerque NM
    FastRat
    Thanks. I had been told that any alcohol based adhesive would eat the rubber backing. Is the 3m stuff safe for the rubber? How much do you need and what's the cost?
    Quote Originally Posted by mrjoshua View Post
    I assume fast rat is talking about spray contact. I have never used it but it should work fine. If you read the instructions I assume it will tell you to spray both the back of the carpet...and the boat....and then let it sit for 5 or 10 minutes. Beware once you touch that carpet to the adhesive/boat.....she aint gonna want to move.
    i dont know if the 3M will eat the rubber...i have indoor/outdoor carpet in both my boats (no rubber backing) & it worked fine...you only have to spray either the carpet or floor etc...you can find it at Wal-Mart or Home Depot...you have to work kinda fast cause the carpet will stick quite quickly!...Overton's & West Marine also sell a glue that they use with the carpet they sell...check there web sites...just trying to help
    FastRat
    Aug 2010
    Albuquerque NM
    Thanks for the advice guys! Josh
    I have used both....The indoor/outdoor glue works best for long term. Get a cheapo trowel with no more than a med tooth. Toss it afterwards. Cleaning it for another use is a bitch.
    Made In The Shade
    Custom Window Tinting
