Project 1993 CP openbow restoration thread.
Results 1 to 10 of 10
    Senior Member 2002CP19's Avatar
    Lake Arrowhead/Lost Lake
    Default Project 1993 CP openbow restoration thread.
    Day 1
    Wish me luck, I'm gonna need it..
    Quote Originally Posted by schick View Post
    Hold it firmly on the ground, a few pelvic thrusts should do the trick. If not repeat till satisfied!
    Senior Member steadymobbin's Avatar
    Apr 2010
    good luck!
    Wowzers!
    Apr 2010
    Rocklin, Calif.
    Cool
    Just wondering, whats the weight diff. between the openbow vs.standard bow
    I dont know the weight of my boat, but i can lift it a few inches off the bungs.
    Apr 2010
    i would say minimum of 300 lbs if not 400 lbs. pm sleeperCP i bet he knows exactly what the difference is
    Apr 2010
    Rocklin, Calif.
    I'm just curious, they had to support where the deck was somehow, with braceing + seating I would think it would be abit heaver...with no motor or pump(intake still in ) I can lift mine about 18"
    Quote Originally Posted by steadymobbin View Post
    actually I don't. Boats are laid-up so differently. The Station wagon is 775-780 lbs tanks and rigging, 980 with the pump and interior installed. The engine ( long block with intake ) weighs 620lbs.
    At 780 lbs the boat is very sturdy.
    S CP
    Why did u get rid of your closed bow cp?
    Senior Member River Dad's Avatar
    Riverside, CA
    So sleeper, only 200 pounds for the pump AND the full interior? Surprising but it makes sense. I would think the pump is in the 75 pound range, so there probably isn't a whole lot of difference between the open bow and the std deck. The deck that is cut out makes up a little bit of the difference for the weight.
    Good thread and keep the pics coming. I've had a few guys ask about an open bow deal and I don't have any verifiable info for them so this will be interesting.....
