short header question
Results 1 to 14 of 20
    Default short header question
    i'm building my headers and was wondering how far past the inside edge before the transom do they have to overhang when running them wet? Right now they are about 8" from the inside lip of the transom. does that much water come out of them or is it mostly steam?
    BRM
    BRM is offline
    Default headers
    headers are best when they are erect
    Jun 2010
    back of boat within 4 inches IMO...
    Senior Member W.O.T's Avatar
    Campo Ca
    Should Be Slight Steam Always. If You Have More Water Than That ever Coming Out Of Headers Your Going To Have More Problems.
    so i should just extend them to just past the lip on the inside of the transom
    Apr 2009
    SW Ohio
    Quote Originally Posted by sandeggo View Post
    bitchin! throw up a side profile. im thinking about the easiest way to fab up some custom shorty upswept headers for twin turbo.
    This is a sbf sprint car kit with LS flanges
    Member bubbledeck55's Avatar
    Oct 2010
    bullshit city az
    Default headers
    i have a set of bassets that look pretty close to that length and they do fine running with the bilge. most of the water gets tossed out the back from the momentum
    Senior Member desrtrat256's Avatar
    San Diego, CA
    That looks buitchen! out of curiousity why are you going with a carb and not the stock efi?
    Quote Originally Posted by bubbledeck55 View Post
    thanks thats what i was looking for. i think my 750 bilge would keep up if i put a hole in the bottom (knock on wood)
    Quote Originally Posted by desrtrat256 View Post
    carb is just simple. efi is something that i would rather not deal with out at the river. more to go wrong, and more complex fuel setup. i am trying to keep it as simple as can be.
    My old small block was toast. cheapest cost to rebuild the Gen1 was 2200.
    I needed to get my carbs redone (600) and a new fuel pump(150). all said and done i was facing about 3k for an old worn out 2 bolt SBC. This 2007 motor was 500 bucks complete. It has barely any miles on it and puts out more horse and torque than the old motor. Its also lighter. I sold all my old smallblock stuff and can do the motor plates and everything myself so the cost of the swap is kind of a wash. Free aluminum, and just my time. seems like a no brainer to me. If I pop this motor i go back to the junkyard with 500 bucks and get another one. 12 bolts later there's a new motor in the boat.
    LS motor $500
    MSD 340
    Vic intake 300
    Carb .... havent bought it yet
    SBF header kit and LS flanges 160
    fuel pump 100
    oil filter relocator 50
    metal for rail kit and mounts free
    pto 70
    total this far about 1500 bucks.
    Gen 1 small block parts were sold for 1700-ish through craigslist
    now that's gna look niceeeeeeee good job!
    thanks i think it looks pretty good. the header kit worked out well too because the drivers side header primary tubes were about a inch longer than the passenger so it matched the offset on that head. the collectors are the same distance from the transom.
    About what size are weep holes and what size bungs for the water lines?
    Senior Member Daddy B's Avatar
    It will make more of a exhaust carbon water mess in the transom having them short but I personally think they sound better, most baffles are 4 inches long for noise police.
