Every jet boaters dream
Results 1 to 8 of 8
    Apr 2010
    Rocklin, Calif.
    Default Every jet boaters dream
    Does anybody know if a very flexible steering cable is available
    Ladera Ranch
    I haven't seen anything different than the teleflex cables, though they can be bent pretty well, but steering input will suffer.
    I've been thinking of going with a v-drive setup using cable, kind of a poor mans calgo, but would probably end up being more expensive and take longer because all the brackets and pulleys would have to be bullet
    Apr 2010
    Rocklin, Calif.
    What about the volvo cables, they seem to work super, for throttle, much better than morse.........can you help..thanks...
    How "flexible" do you need it to be ? are you trying for tight radius's in the rigging or ? just curious ? Tom
    Apr 2010
    Rocklin, Calif.
    Yea tom fairly tight radius..for rigging
    GG the modern cables with squeeze down to 8" radius quite readily however as I'm sure you know this shortens effective cable life tom
    Apr 2010
    Rocklin, Calif.
    Thanks Tom, I was just curious if they've been improved over the years ..my cable is in pretty good shape
    U-FLEX has a published 7.9" minimum radius. Teleflex is what I'm using, with only one bend, at the helm, seems to be holding up ok. Morse cable is no longer.....snapped up by Teleflex. My buddy has a Detmar set-up in his Wriedt, that has a bunch of bends..... it's smooth as silk.
