should I move the motor back?
Results 1 to 12 of 12
    Default should I move the motor back?
    My motor seems to be way farther forward then most the boats I see. From what I have been told is my pump is the old style that uses a longer shaft than whats out there now. the only way I could see moving the motor back would be to get rid of the H-bar and run a single Ujoint. Any ideas? I'm thinking it might help to get rid of the porpoise I have.
    Senior Member wildstreak's Avatar
    Feb 2009
    East Texas
    Single U joint will likely result in a drive line failure.
    Feb 2009
    East Texas
    And moving the motor back will not reduce porpoise, it will make it worse. A Place diverter will solve your porpoise problem.
    Quote Originally Posted by wildstreak View Post
    Actually putting the rideplate on gave me the porpoise. Diverted only helps all the way down. Any other slot it porpoises.
    Member ocelot's Avatar
    Mar 2010
    Default porpo no funno
    Have u checked to see if your bottom needs work? that ls motor is lighter right? that should help too.
    The Man cordog009's Avatar
    East Texas
    Probably gonna have to have some bottom work done to get rid of the porpoise.
    1984 Youngblood TX-19 SOLD
    is your boat faster when it's got the porpois going on? The ride plate may need to be lowered, to settle the porpois. Moving the engine back will really un-settle the boat, inducing porpois.
    The bottom is straight. The shoe is level with the keel. Shunning the plate had no effect all last summer
    Mar 2010
    do your strakes go all the way to transom? could u post some bottom pics?
    It has two outer strakes that go to the transom on each side of the intake and a inside strake that terminates at the intake inlet, the bottom of the boat is 7/8" thick in some places and its all straight
    How many degrees up is ur ride plate? It should be 2-3 degrees up from keel.
    I will have to check, I have had it every which way. played with shims alot last year
