Drag boat using a jet
Results 1 to 11 of 11
    Kent, WA
    Default Drag boat using a jet
    How much power does it take to run 8.0 w/ a jet boat ?
    I'd like to get a few of known examples ?
    A dynoed engine power figure at a rpm that runs this 8.0 et ?
    Please no guess on the power. like " I know a guy that says his makes 1350 hp and runs 8.02 "
    B1 Racing cs19's Avatar
    Really depends on so many different things, jets take finesse to make work right.. You Can't just say with this gear, this prop and this much power you will run 8.0.
    On average id say 1100-1150hp naturally aspirated at 7000-7200 should push a decently setup tunnel to 8.0 at a fast track. A blown deal will take more, lots of weight.
    Do your research on the hull you choose and what parts you use, you'll be frustrated if you end up with the wrong stuff.
    So Cal
    there you have it. an educated answer
    Kent, WA
    Hmmm, Thank You !
    I'm "fixing" a broken engine for a guy. I'm guessing it was at the 1150 hp range as it had been run ?
    It ran 8.47 as it was on a bad tune up.
    What kind of trouble will it be to change the engine to the 1500 hp range ( both engines are blown BBC ) ?
    8.47 with 1150 HP isn't real great to be honest.
    Making them 1500 HP is up to you, not sure I understand the question. As far as the boat goes you just need to make sure it's setup well and The pump has the right impeller and parts to handle the power.
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    The heavier the boat and engine, the more power it will take.
    The "poor" setup boat and pump will take more power.
    In the historically typical midwest jet boater mindset. Keep adding power until it performs.
    QE 439 Twin Turbo
    So Cal
    CS is right ... set up and quality pump parts are everything. Also Info has a good point ... adding hp to overcome a poor set up or too much weight isn't going to help anything.
    No one here will be able to pull an answer out of their hat and give you a "guess-timate"
    Only way to know if you're making progress is to get it out on the water and do some testing. Sorry ... but that's the real answer.
    There are too many varibales.
    Led
    Led is offline
    Senior Member Led's Avatar
    Jul 2010
    Time, Patience, and $$$. Also just talk to some guys (that run good) with your hull or similiar and try to put your strategy together.
    Senior Member UNASHAMED's Avatar
    Sep 2008
    Tucson, Az
    Set it up right and you can use less power...
    "Don't make me get my penguin"
    Kent, WA
    I totally agree and do understand your thoughts and great points !
    Thank You, we'll get it on the water and gofrom there !
    Thanks again, Wiz
    Silverdale, Washington
    Thanks again, Wiz
    Whos boat Brian?
