Will this continue to be a problem??
Results 1 to 5 of 5
    The Good mrjoshua's Avatar
    Aug 2010
    Albuquerque NM
    Default Will this continue to be a problem??
    This dominator out of my new boat has fought me every step of the way. No surprise when i pulled out the shaft and found this. Will the gouges be a problem for the new bearing? do i have to just touch it up?
ID:	107927   Click image for larger version.
ID:	107928   Click image for larger version.
    B1 Racing cs19's Avatar
    Thats pretty beat up and is most likely going to be a problem. The bearing face lays up on that surface and it needs to be correct. There is barely any original surface left there in the corner but the bearings have a rounded edge so it will not be able to contact that surface anymore. A good machinist could maybe fix that, 90% of them will make it worse though in my opinion. The hammered area where the seal goes is the least of your worries, its the beat up shoulder that bothers me.
    Clean it up with degreaser and take another pic
    Senior Member speedealer's Avatar
    Albuquerque,N.M.
    hey josh bring it buy the shop and i'll throw it in the cooker and clean it up so we can get a good look at it. bring the brg retainer also.
    Aug 2010
    Albuquerque NM
    Quote Originally Posted by speedealer View Post
    I'll bring it in tomorrow afternoon after i get off work. Thanks.
