Really need help
Results 1 to 14 of 28
Really need help
    Apr 2010
    Rocklin, Calif.
    Default Really need help
    I've got a 498 BBC 14:1 popping out the ext. at low rpm..1300.. higher rpm seems to be fine, the popping is one side only, so i've done this ( by the way it's all msd) pulled out all old fuel (110) changed & indexed new plugs, ran all the valves (solid roller) put in new box,tried differnt coil,differant cap-wires, took carb's apart-everything is clean, changed out power valves, ran compresson 195-205, no splices in any wiring all wiring point A to B grounded to batt. and block (no paint under block ground ) batt. cabels all solderd,#1o ..............Need some help here
    Mar 2010
    Clarksville, TN
    I had a similar problem and my timing was off . Reset the timing and problem went away.. Just a guess but a easy check
    And I would put a new set of plugs in also
    Sounds like a dirty carb issue. Maybe a little crap in the idle circuit and leaning it out. At 1500 you are in transition stage. Sounds like it might be a bit lean.
    Apr 2010
    Rocklin, Calif.
    Cool
    I'll give that a try, It sounds reasonable, If it work's,my son is right, I'm a dumbass
    Senior Member GRoper's Avatar
    I had that problam a long time ago. turned out to be a flat lobe on the cam but with the roller set up i doubt it.
    Silverdale, Washington
    Dbl G, can you explain a bit more on the popping?
    At what rpm does it start popping and at what rpm does it stop popping?
    Does it do it on the trailer or just under load?
    More details on carb?
    I've had a lobe go flat and it did it under load and didnt stop till I let off the gas. Given what youre describing as well as it being a roller, I cant imagine that being the issue (but what in the F do I know)
    Gents, for those that havent seen Dbl G's boat, it's a badass MFR and the quality of it is 1st class. Let's get this thing figg'rd out so he can take me for a ride.
    If it work's, my son is right, I'm a dumbass
    Senior Member lbhsbz's Avatar
    Long Beach
    Switch the purple and green??? wires coming out of the distributor.....msd has a way of setting them up backwards.....timing problems result, and popping is common.
    Orlando.FL
    If the wires are crossed the timing will be retarded so timing would be flat.
    Apr 2010
    Rocklin, Calif.
    Ok took carbs apart cleaned every thing with carb cleaner, blew air through everything-still popping..man I'm stumped,timing is good set at 40 deg. (it likes 42) carb's are 850 quik-fuel fuel press. is 7# The whole thing is it ran like a champ when i took it out of the old boat, put it in this thing and it act's stupid! It did set for a year and a half, and I did shim the dist. it did have some slop.........Damn thing pops one side only, above 1500 rpm it's fine
    A compression test couldn't hurt....rule out a toasted valve...head gasket...holed piston ect.
    Apr 2010
    Rocklin, Calif.
    Ok did that,#1-195, #3-200,#5-195,#7-200,#2-200,#4-205,#6-200,#8-200.....looked at vavle springes, seemed to be fine,this engine does not have alot of time on it..Man I'm getting the ASS
    If it has zoomies than you can isolate the bad hole but to me it sounds like a straight up missfire Check you F.O.and then start pulling wires to find the bad hole and then concentrate your efforts there.
    Apr 2010
    Rocklin, Calif.
    Cool
    Quote Originally Posted by flat screwd View Post
    No zoomies here,I spoke to john avery today he tunes for paul phaff, he's thinking broken valve spring so I'm going to borrow a spring-removel tool and look,I'm not sold on the idea, but what the F$%K can I do........hey guys I really appreciate the imput..keep it comming,I do know theres a handel here
    Check for a vacuum leak at the manifold on that side with sure start?
