[Question] Need a bowl pic.
Results 1 to 10 of 10
Need a bowl pic.
    Ralls Precision Machine Ballztech's Avatar
    Mar 2010
    Default Need a bowl pic.
    Does anybody want to share a pic of you Race, or "Detailed" bowl. Intake side.
    I'm messing around with mine.
    PMs work to.
    Thanks in advance.
    Mar 2010
    Default Thanks Rich
    Got one of the other side?
    Shell Knob, MO
    Here's one of a race bowl before it was put back together.
    Duane HTP
    Shell Knob, MO
    Opening up an old Dominator bowl.
    Finished bowl;
    Duane HTP
    Mar 2010
    Default Thanks Duane!
    Thats what I needed to see.
    Ill put a couple pics of mine when its done.
    AR
    DJG
    DJG is offline
    Duane HTP
    Hey Duane did you ever run that bowl or is it still in prototype? How did you put it back together? Weld or bolt? Why did you cut it apart to detail it, or is there some other top secret(proprietary) stuff your doing? Just wondering.
    Shell Knob, MO
    All of the above. Yes we have run it with great success. It was welded back together. It was cut apart so we could do some extensive changes inside the bowl.
    Duane HTP
    Mar 2010
    Default Progress
    Opened her up a lil bit, old style dominator bowl.
    Your split job is nice.
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    what tools did you guys use. i tried a dremel w no luck
    Mar 2010
    Default Tools
    Quote Originally Posted by HBInHeat View Post
    Ababa Qa. 619-440-1781 I picked up a couple carbide burrs and made little extension couplings. They tend to get loaded up so you'll need to use some sort of lube/coolant.
    The little bearing wheel really helped out too.
