watts by-pass valve
Results 1 to 7 of 7
watts by-pass valve
    Default watts by-pass valve
    anyone out there know how many turns in or out yours is set at and the pressure reading, the valve is 1/2 inch.
    I just installed one but i haven't installed psi gauge yet
    Lexington, KY
    Exclamation
    Here's all the information you'll ever need.
    http://www.performanceboats.com//showthread.php?t=7371
    HJ
    i keep mine were as soon as the motor is started, it puking out a small stream outta the back, then as soon as i throttle up, its bypassing pressure pretty good by then. setting the thing with air pressure or a water hose is pointless, trust me
    rex marine told me to start with 3 turns out
    and the valve was reworked to operate at 5lbs open/ 50lbs closed
    The Earth
    Blog Entries
    24
    A pressure gauge is the only correct way to set the valves for correct block pressure in your application.
    Lexington, KY
    Talking
    Go to tractor supply and pick yourself up a $30 pressure gauge!
    HJ
    AIR POWER TAPPED OUT's Avatar
    Las Vegas NV - Big River CA
    I set mine by hooking it up to the garden hose and having a pressure gauge on it. It worked very well.
