Need Help with Rail Kit Installation
Results 1 to 12 of 12
    Senior Member XClutchboy725's Avatar
    Alta Loma, CA
    Default Need Help with Rail Kit Installation
    Hey Everyone!
    Well, after almost a 3 year hiatus "Dad's Boat" is making a comback!
    I finally killed the 454 and am in the final stages of putting together a Dart 540. (working with Steelcomp and cstraub on the combo)
    During this repower project, I will also be eliminating the cast aluminum 4 point mounts in favor of a rail kit.
    Does anyone have a fixture available that I can borrow to help with the pump alignment?
    I think Bigamist had something that even took the place of a mock-up block, but I'm not really sure what the hot ticket is?
    Help?
    Got Circus Midgets??? BIGAMIST's Avatar
    S.F.V.
    That was me, but it belongs to Jim Brock, you could try callin him.
    Havn't seen your boat in a long time, one of my favs ....I think we might need some pics!
    When I die I want to go nice and peaceful in my sleep like Grandpa did, not screaming like the other passengers in His car.
    S.F.V.
    Alta Loma, CA
    LOL - There she is in all her glory!
    Can you PM me Jim's number?
    B1 Racing cs19's Avatar
    Ive got one but its being used at the moment, maybe a week or 2 you could use it.
    Quote Originally Posted by XClutchboy725 View Post
    We have designed a fixture but not produced it just yet ,Josh has been using an Iron block for years Its a little bulky but works well Tom
    Alta Loma, CA
    The timing could be right with this one! I probably won't start the project for a few weeks.
    where are you located?
    Jeff
    Orange County
    Alta Loma, CA
    Orange County
    I work in Irvine. I'll be in touch!
    Senior Member gregb's Avatar
    Redondo
    When the engine is out, bolt the rear mount from the 4 point back in the boat. Then bolt the rear plate from the rail kit to that and you will be able to see where to mount the rails or cut down the plate if you are mounting the rails at the top of the stringer. Then it's just a matter of adjusting the front mount or the rails so you get the engine at the angle you want. What kind of hull?
    (you could do the same with the front also, bolt it back in and attach your front plate to see where to cut or mount the rail)
    Don't forget to fill in the old holes with some dowels and glue or epoxy.
    Alta Loma, CA
    I got in touch with Jim Brock (thanks Bigamist) and I'm going to borrow his fixture in a few weeks.
    Thanks for the help everyone!
    Jeff
    WET MEMBER SANGER-RICH's Avatar
    AMERICAN CANYON
    check your PMs
    2008 & 2012 NJBA HIGH POINTS CHAMPION
    2012 SKI HYDRO ET RECORD HOLDER AT 9.51
    2012 SKY HYDRO SPEED RECORD HOLDER AT 116.27
