trailer redoing
Results 1 to 14 of 15
trailer redoing
    Mar 2011
    Default trailer redoing
    just wondering what kind of paint i should use and can you actually paint brush it on.
    Seen it all....rattle can is decent. If you have the time...auto paint.
    Made In The Shade
    Custom Window Tinting
    Kingman/Golden Vly, Az
    make sure you clean the steel real good & primer it 1st...if you have a compressor, your better off buying a gravity feed sprayer from Harbor Freight (works very good) & a "good" quality Marine paint & go to it ...just sayin' my .02 cents
    FastRat
    NAPA's Martin Senior paints... They tend to not get so hard and chip easy
    http://www.martinsenour-autopaint.co...PCC/Flyer.ashx
    Senior Member sleekcraft137's Avatar
    Star, ID
    I am a paint rep for AKZONOBEL paints, there's a million ways you can go however since its a trailer there is one easy product you can go with. Glidden porch and floor polyurethane, its a true urethane as well as a "DTM" direct to metal. No priming needed. It will flow and level out like glass.
    And the new project begins!
    Quote Originally Posted by sleekcraft137 View Post
    Exellent aviation paints too = AKZONOBEL paints
    Star, ID
    yeah we do Glidden,martha stewart,ralph lauren,devoe, dulux, sikkens, sikkins automotive, flood, flotral. plus we do all the can ink for coors, coca cola and anheiser busch. As well as the entire USA navy, and several auto makers etc... BLAH BLAH BLAH. Anyways, that porch and floor is pretty rad stuff.
    Denton, TX
    Side bar here. How many versions of matahorn white are there? Ya know king air white. I'm having a hard time finding it
    Sent from my iPhone using Tapatalk to hide from the IT dept.
    Where might one find this paint.....My trailer has so much overspray on it...its next on the hit list.
    Las Vegas, All Over..
    Interesting, i have a shop in boise with a sikkens mixing bank and the rep for this area lives in california..you can do the automotive stuff too??
    H20 we use alkyd enamel, thats whats on most trailers, or automotive paint if you want higher end and more gloss or custom colors. the alkyd runs about 28.00 a gallon..the stuff i use is actually made in salt lake, you can buy it at national coatings in slc. or if you need help let me know
    nice way to do it is to blast the trailer clean and start from scratch, how solid is the paint on it now?
    Star, ID
    Quote Originally Posted by 78 Charger View Post
    your rep is an independent dealer rep, I am in a different division. I deal with large accounts like Home Depot and Walmart.
    Star, ID
    Depends on where you are located, if you are in Cali good luck on finding anything decent in the alkyd resin/ urethane world. Anywhere else can be found at home depot in the porch floor bay.
    Star, ID
    FYI the Glidden PF80xx is a polyurethane with alkyd resin "long oil" Pretty much any oil base product will now consist of alkyd resins over a true oil.
    Star, ID
    BTW, if anyone needs a gallon of this in the Boise area I have an extra gallon of light grey that I dont need. Anyone want it?
