Impeller help
Results 1 to 10 of 10
Impeller help
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Default Impeller help
    I just picked up a new bronze impeller for the swtd and was wondering if I should return it if this is normal.the casting seems to have left holes that go through to the other side I can blow air against the blades and feel air on the back side. Is this how they all are they obviously machined it and let it go out like that.yrr
    Have seen this in bronze from time to time (casting pits are not completely unusual ) post up a pic , any idea who made it? Tom
Name:	2011-03-13 16.18.25.jpg
    Senior Member wildstreak's Avatar
    Feb 2009
    East Texas
    If I just bought it new, I would return it. I have seen some casting flaws in bronze but not holes that go all the way thru.
    Quote Originally Posted by HBInHeat View Post
    1
    Good Pic What Brand ?
    Concord, CA
    Default holes
    If thats unused and has casting holes like that, ts will be way worse after you run it. The pits will cavitate and burn lots of bigger holes. I received one like that, and after one season of use, Aggressor replaced for free.
    Jerry
    B1 Racing cs19's Avatar
    If your stuck with it I wouldnt worry about it too much. Run it a few times and check on it.
    Its new never used so I think I should be sble to exchange it
    Senior Member 787chuck's Avatar
    MorePark
    the way I see it your paying the same with or with out the holes i would want it with out just my .02
    I got one like that brand new, was not happy about it and was adviced to run it. It was never a problem, but took it out at the end of the season and sold it, after buying a new SS.
ID:	109192 Click image for larger version.
ID:	109193 Click image for larger version.
ID:	109194 Click image for larger version.
ID:	109195 Click image for larger version.
