Another All Aluminum Twin Turbo Jet Boat Project.
Page 1 of 21 1 2 3 4 11 ... LastLast
Results 1 to 14 of 285
    LP-25.com Infomaniac's Avatar
    New Port Richey, FL
    Default Another All Aluminum Twin Turbo Jet Boat Project.
    I guess the 522 project will go in the corner.
    Just got home with a pile of parts. Just needs cleaned up and assembled. Brodix tall deck. Brodix head hunter heads. Intake already setup for 16 injectors.
    Will need to tame it some. I'm OK with 9.4 compression but 900 lift and over 400 on the seat is a bit much for what we will be doing.
Name:	block crank.JPG
ID:	109125   Click image for larger version.
ID:	109126   Click image for larger version.
ID:	109127   Click image for larger version.
ID:	109128   Click image for larger version.
    QE 439 Twin Turbo
    New Port Richey, FL
    We'll take everything from the manifold up, turbos and headers off this project and insert the new engine. Theres nothing like changing direction before you get done with the existing project.
    QE 439 Twin Turbo
    Atlanta, Texas, United States
    GO FOR IT!!! I think that weight change will really help you!
    Gear
    New here Beer:30's Avatar
    Bakersfield, CA
    We'll take everything from the manifold up, turbos and headers off this project and insert the new engine. Theres nnothing like changing direction before you get done with the existing project.
    What's the cubes on the Brodix setup????
    New Port Richey, FL
    Thanks Steven. I think the boat will like the lighter engine
    It's a 4.250 stroke 565
    QE 439 Twin Turbo
    Bakersfield, CA
    Ah. Nice! Will it stay "std" or will it go another .030-over and be a (guessing) 572?
    New Port Richey, FL
    The bore is pretty close to max at 4.600
    Don't care to buy new pistons at the moment.
    QE 439 Twin Turbo
    Bakersfield, CA
    The .030 comment was more of a question of - how are the bores? Was the engine used much? Will it NEED machining?
    okie, lake Texoma
    Now thats what I'm talkin about! 565cid, light weight, turbo'd ,alky engine. That should bout do it.
    Thats a nice pile of parts you come up with there Ron. That boat should REALLY move out with 150+lbs less weight.
    H8-2-W8
    [email protected] first pass
    New Port Richey, FL
    It has 5 new sleeves and the rest are OK.
    But the entire engine was fresh and ready to assemble.
    QE 439 Twin Turbo
    "BEER BUDGET RACING" Bodean's Hammer's Avatar
    Okmulgee, Oklahoma, United States
    Man I thought the other one was insane.....
    New Port Richey, FL
    Thanks man. Now that you have spelled it out, it brings back memories.
    The first time I fired the Cougar's blown alcohol engine up, I thought to myself. What the heck have I done.
    Mrs. Infomaniac is not to thrilled about it.
    QE 439 Twin Turbo
    Senior Member hotbo's Avatar
    lake Ouachita AR
    she will get over it
    very nice Ron
    WFLC
    2011 Performer SS
    built by Scott Seastrom.
    Tri-Cities, TN
    Nice additional parts Ron. Can't wait to hear her fire up.
    Chris Straub
    Straub Technologies
    3HP is an A$$ Whooping!!! JW
