^^ Holley Fuel Pressure Gauge Question ^^
Page 1 of 9 1 2 3 4 ... LastLast
Results 1 to 14 of 117
    "Floatin' Motor" BoNeS's Avatar
    Jun 2010
    Surprise, AZ
    Default ^^ Holley Fuel Pressure Gauge Question (RESOLVED) ^^ WOT Fuel Cutout Prob Now!!
    I installed a new Holley fuel regulator, it's supposedly preset at 7lbs but i'm not getting any reading of pressure on fuel pressure gauge. To increase the lbs. i simply turn the screw on the top clockwise, right?
    FYI, it's a BBC and the pressure gauge is mounted on the fuel log.
    Last edited by BoNeS; 03-18-2011 at 04:33 PM. Reason: Prblem fixed, have new 1 that might be related to solved problem.
    Quote Originally Posted by BoNeS View Post
    how did you plumb it? M
    Jun 2010
    Surprise, AZ
    Tank ---> fuel pump ---> regulator ---> carburetor
    New here Beer:30's Avatar
    Bakersfield, CA
    Do you KNOW it has actually primed and is pumping liquid?? May be just air (hence nothing to move the needle of the gauge) and zero fuel??
    Senior Member Fonz69's Avatar
    Frozen Tundra, WI
    just to make sure you have the fuel in and out hooked up right on the regulator right?
    Yes loosen lock nut and turn center in a regulator clockwise to increase psi, I would start around 6 psi
    is it a dead head (no return to tank) or bypass type (return to tank)?
    Jun 2010
    Surprise, AZ
    Yes, was out on the lake yesterday running it.
    Quote Originally Posted by Fonz69 View Post
    Lol, yes it's hooked up right...and yes it's a dead head.
    Bakersfield, CA
    Faulty gauge perhaps?
    Jun 2010
    Surprise, AZ
    Hmmm, that could be a possibility.
    Dallas, TX
    Did you use Teflon tape on the fittings? I have seen numerous times where little strings of the tape break off and clog up things like needle and seat and gauges. There is no need for sealant on flare fittings. It is the flare that seals not the threads.
    Jun 2010
    Surprise, AZ
    No i didn't use teflon tape on it, i actually just gave it a few turns and it registers at @8lbs. Took it out this afternoon and it seems to loose fuel flow and pressure a few seconds at WOT. I'm not understanding this fuel issue at all.
    reason for the question is there 2 types of regulators. one is for a bypass system and the other for a constant pressure regulated for delivery to carb. Now you loosing pressure qwik? Might want to check! Also the plumbing question was how into the regulator. Your'e response is the standard deal but the regulator was what I was asking
    Jun 2010
    Surprise, AZ
    From the fuel pump it plumbs into the bottom of the regulator the out to carb from the side, the other side is capped off cuz it's a ''dead head'' setup..(no tank return line). As far as the pressure, it drops only at wide open throttle after a couple of seconds of being at WOT. It's almost as if the fuel pump (Blue Holley) can't keep up with the consumption of the carb/motor. I'm using -6AN lines for the fuel plumbing.
    Dallas, TX
    What kind of filter and where is it? I had an issue on my cruiser similar to what you are experiencing. It was a bad fuel filter before the pump. What carb?
    Sep 2008
    Yuma, Az
    use ALL -8an lines for the fuel system and see if it helps. what kind of fuel filter are you using? make sure to not use many "home depot" style fittings, because that will restrict flow. i could see that being alittle problem. as far as the guage, toss it, and try another.
    might need to go this route..
    boatless....
