bowl bushings location?
Results 1 to 3 of 3
    Senior Member HBInHeat's Avatar
    Huntington Beach, California, United States
    Default bowl bushings location?
    So i rebuilt my pump got a little ahead of myself and popped the tail shaft bushings out before I realized i needed to put them back in the same spot they came from. Little help would be appreciated.
  2. #2
    The location does not really matter, as long as there is no interference. Dominator bearings can be added to a berkeley bowl, they are longer, more bearing surface.
  3. #3
    ok maybe i shoulda added its an aggressor bowl and it has like grooves and notches and what not so I'm not sure if the bearing should straddle the grooves or not
